OT: Anyone with an 96 integra gsr
Username: Volfenhagking1600
SSD Wangin, Shawano, Wis... USA
Post Number: 1220
How much room is in the trunk/hatch for a sub? Would a 15" BTL fit?
Thanks
Jamie
Username: Bonhamd
TC, MI USA
Post Number: 774
someone here has a teg and had 2 15 inch Qs sealed
i have a BTL 15 for $240 shipped
Post Number: 1222
is the btl loaded?
Username: Naledge503
LowDownForum.com
Post Number: 3918
I have a 95' Teg. I had my Q 15's sealed in a 5.1cuft enclosure. You can definitely fit a 15" BTL in there.
Post Number: 1223
alright i might be buying an audiopulse revo 15... any chance of that fittin?
Username: Insearchofbass
Post Number: 9594
"someone here has a teg and had 2 15 inch Qs sealed"
That was Naledge he sold them recently
1995 Acura Integra RS
Subs: 2 Fi Q 15's dual .7 ohm
Enclosure: Fisher Customs 5.1CuFt Sealed
LowDownForum.com
Post Number: 3919
Revo would fit too. You could actually fit a pair of 15" Revo's sealed.
Post Number: 9595
haha you posted right after
Post Number: 1224
ok sweet... what kind of amp would i shoot for on a Revo Dual 2 ohm... somethin cheaper. 1500 watts or so
Username: Bonhamd
TC, MI USA
Post Number: 775
the BTL has no options
Username: Th3pwn3r
I compensate...
Post Number: 8251
You should probably upgrade you're charging system too. Hondas don't exactly have huge alternators to support too much power. I would only run 1k RMS at most.
Username: The_image_dynamic
San Diego, California
Post Number: 4120
Rob is on the right track. That car has a 95 amp alt so: 95 x 12.8 = 1216 - 20% for efficiency loss = 972.8. Factoring in your front stage amp and the current draw that the car needs to operate, I would go no higher than 800RMS for the sub amp. You could probably get away with 1000RMS if you don't plan on cranking it up constantly, but your alt won't last very long.
Username: Nyyfan13
15 Mag USA
Post Number: 9875
Username: Th3pwn3r
I compensate...
Post Number: 8257
There's nobody stupid here Yanks! Well, maybe now that you're here ^_^ Just playin man.
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 1855
pwnt lol :D
I guess it's bad that I run 4krms on my stock alt...
Post Number: 9596
"Rob is on the right track. That car has a 95 amp alt so: 95 x 12.8 = 1216 - 20% for efficiency loss = 972.8. Factoring in your front stage amp and the current draw that the car needs to operate, I would go no higher than 800RMS for the sub amp. You could probably get away with 1000RMS if you don't plan on cranking it up constantly, but your alt won't last very long."
Theres a guy that thinks like I do....I was also beginning to wonder if many people even planed on running amps for highs let alone the cars basic electrical needs
"I guess it's bad that I run 4krms on my stock alt..."
you run an upgraded battery or two dont you....Brad is looking at it from a factory alt situation only
