I have the new bin and getting nearly all channels but for some reason I cannot get 505-511-512-515-519-520-523-525-526-527-528-529 I did blind scan, satellite scan, and TD scan. Any help
- Is this a new installation or yo had this working before? - Do yo have 1-LNB or 2-LNBs? - What kind of receiver yo got? - R yo using DISEqC switch? - List all yor hardware - List in detail will get yo up and runing in few minutes
If this is not a new installation select ch-505 look in Antenna settings see if yo got signal quality
If this is a VU-Sat there is a problem caused by Nagra in disabling some channels when yo do blind scan
Solution Avoid blind scan as much as yo can Write all yor antenna settings followed factory reset Enter all antenna settings followed by channel scan no blind scan
I have a Pansat 2700A using a Dish 1000 HD Dish installation. In the past when only using a DishPro LNB, I got all the channels. Only now with the Dish 1000 installation, which I use for HD Dish channels. I then disconnect from the 622 DVR and hook up to the Pansat 2700A and the channels listed are gone but all the others are present.
Antenna Settings EchoStar 7 LNB type DishPro; LNB Local Freg. 11250; 22 kHz off; DisqC #1; Legacy SW None; TP (41) 12429 v 20.000; Position Disable; Satellite Scan All ---- EchoStar 7.10 is the same except DisqC is #2. If I understand you, I need to do a factory reset and reset as above, is that correct.
It sounds like a conflict but not a hardware Yes I would write down all antenna settings Do factory default Assign your old settings in antenna settings Chan Scan 110 first (not blind scan) Check 110 channels Chan scan 119 next (not blind scan) Yo should be runing right away
