No sound from speakers
Username: Fox23
Hanover, NH USA
Swapped out cd/stereo in jeep but blew a fuse in the process. Replaced fuse but now have no sound from speakers. Everything else works. Did I fry something else?
Username: Kaerfpl
Spencerport, NY USA
Post Number: 921
Check for a Factory Amp
Username: Fox23
Hanover, NH USA
Thanks for response. I didn't have another power wire hooked up. Apparently it is described as "P. cont". They are working fine now. By factory amp, do you mean there is something else installed here somewhere I'm not aware of? Can they be small and where are they usually stored?
