I am using a Dish 1000 with dp/34 swithch. I use DishPro lnb, 11250 freq,& Ports are right. I only get some of the channels. I do not get the channels 505,511-515, 519,520,525-530. They show up on EPG but when you select it says No Signal. I have the latest bin installed
I need help adding a new satellite (118.8W) on to my Puff converted Pansat 2500. I have already installed a 33" dish with circular LNB designed for 118.8. thanks}
