C-Band satellite receiver
Username: Tasmanian_satellite
Post Number: 55
I would like to know if it is possible to use a C-Band satellite receiver and a be3v dish to receive C-Band signals
Username: Popol_vuh
Post Number: 48
You'd have to get a dish at least 4 feet in diameter and with a different LNB... Dish diameter depends on wavelength but also distance (azimut) to satellite and transponder signal strength as well.
So the short answer is: No with dick and bev dish and LNB, you'd have to get a larger dish with appropriate LNB. Fortec dish combos in that size are about $150 or so.
With that setup, your existing FTA should be able to pick C-band. So for the receiver the short answer is: yes, it will work.
Post Number: 56
thanks alot, and for the advice
Username: Mucho
Post Number: 260
The size of Dish depends on your location
and the satellite you want.
With this LNB you can pickup both.
........C/Ku Chart.................
Post Number: 57
great info and thanks for the photos..really appreciate it..
Username: Kingsatman
One_eye_jack
Post Number: 300
Hey Hawk
He is asking is it possible to use a be3v dish?
Simple answer is no!
The foot prints yo got all depends on geographical location as well as orbital location
This is the link yo need:
http://lyngsat-maps.com/america.html
- Select orbital location:
- Select desired C or Ku off that orbital location
- Map will display Max and Min dish size
- Yo take average for correct dish size
- Keep in mind Min gets yo 50%, Max gets yo 100%, average dish size will be about 75% with clear sky view
This is an example for Orbit. Loc. 103W
http://www.lyngsat-maps.com/maps/amc1_c.html
I learned all from King-Tapeman
God bless yo king for teaching me foot prints
And fixing my yo yo
One_eye_jack
Post Number: 310
White Hawk is the same imposter Yukon along with many other countless nick names
As usuall posting wrong usless info confusing members and his images got nothing to do with FTA
Username: Tapeman
New York City in-HD, NY
Post Number: 2853
bump
