So i accidentally broke a tweeter, now what?
Username: Jasonli18t
In the midst of my first component install, i tore the silk dome on one of my tweeters I have an arc audio component set...what do i do now? can i just get a decent pair of tweeters and use them with the arc drivers and crossover? or do they need to "match", and be very similar or identical to the original pair? I want to get this installation done, and since this was an inexpensive component set, i assume that the tweeters probably werent anything special, so perhaps i could take a crappy situation and turn it into a better one by getting some better tweets. ideally id like to pick them up at a retail store or audio shop since i dont want to wait for shipping (my car is all torn apart for the installation).
thanks for any help.
Username: Exige
CDT, Audiopulse Dealer
Post Number: 429
PM me with the model number on that Arc set. I'll look into it for you and see what would be a good match. You'll be able to get a new pair of tweeters. It's simply an issue of finding a good pair that will work with that set.
