Silver Member Username: Rds2oo8MN Post Number: 246 Registered: Nov-06 | can you hook up subs to a factory stereo 2002 buick lesabre is what i drive if that helps? |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 17001 Registered: Jun-06 | Sure. Quick enough answer? Now ask about all the rest lol. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 17002 Registered: Jun-06 | That is such a loaded question I can't begin to dive into. |
Silver Member Username: Rds2oo8MN Post Number: 247 Registered: Nov-06 | o ok well im on craigslist looking 2 buy some cheap subs for about 300 sub n amp |
Gold Member Username: Surferdude9371Im BTL Bumpin Post Number: 1018 Registered: Mar-07 | some factory hu you can depends if it has the rca outputs if not there are ways to get around it i just dont know how |
Gold Member Username: Naledge503LowDownForum.com Post Number: 3862 Registered: Jun-06 | Line out converter(LOC). Wire to one of the speakers wiring. Then from the LOC run the RCA's to the amp. |
Silver Member Username: GibsonguyStorrs, CT USA Post Number: 144 Registered: May-08 | LOC |
Silver Member Username: Rds2oo8MN Post Number: 248 Registered: Nov-06 | it doesnt have a cd player all it has is a cassette so does that mean i pretty much need a deck or no? |
Silver Member Username: WaresgaragestereoFort Valley, GA Post Number: 208 Registered: Mar-08 | what size subs? How many subs? do you want sound quality, loud sould quality or spl? Look at this. its 2 12s in a box for 169.99 http://www.cardiscountstereos.com/catalog%20page.asp?Product+%23=07DC104 u said 300 for subs and amp now take the other 130 and get a good amp. personally this is what i'd use. i build all my boxes from scratch tho. this is all i can do with the information i have. |
Silver Member Username: WaresgaragestereoFort Valley, GA Post Number: 209 Registered: Mar-08 | in that case yeah a cd player wouldnt hurt. i mean w/ all due respect, dont really make much sense to use a cassette player w/ a system. LMAO. back to square one i'd say. |
