Bronze Member Username: Vivi2000Post Number: 34 Registered: Aug-07 | Right now i plan on getting a new stereo, but in the mean time i want to hook up my subwoofer. I just have a stock stereo now, and need a rca output. My friend has a speaker wire to RCA converter in his car, but I dont have a way to contact him soon, and i dont know the name of the thing. Does anyone know the name of this and where I can get one at. |
Silver Member Username: WaresgaragestereoFort Valley, GA Post Number: 205 Registered: Mar-08 | ur amp doesnt have speaker level inputs? it should have speaker level and rca inputs. ur amp users manual should ezplain this... |
Silver Member Username: HowtoeatapencilPost Number: 140 Registered: Mar-08 | Line Output Converter |
Silver Member Username: HowtoeatapencilPost Number: 141 Registered: Mar-08 | Wal mart has one for like $20 that works pretty well |
Bronze Member Username: Vivi2000Post Number: 35 Registered: Aug-07 | No my current amp is a crappy walmart brand that im using until i get money for some good stuff. Also how is the quality on that LOC compared to a stereo's RCA output. I know it will be worse but is it highly noticeable, because I used to ride with my friend a lot and his sounds really good even with a stock head unit. |
Silver Member Username: HowtoeatapencilPost Number: 142 Registered: Mar-08 | Mine sounds fine |
Bronze Member Username: Vivi2000Post Number: 36 Registered: Aug-07 | http://www.walmart.com/catalog/product.do?product_id=1863065 That is what I should get right? Also when I reset the gain on the amp, I should make sure the levels/gain on the LOC is at maximum right? |
Silver Member Username: HowtoeatapencilPost Number: 154 Registered: Mar-08 | ^^^^ thats what i have, im not sure about the gain thing, your going to have to ask someone else, but i think i have mine all the way up |
Bronze Member Username: Vivi2000Post Number: 43 Registered: Aug-07 | Thanks a lot, I didn't get that one because the car stereo shop here had a much simpler one for the same price. I put it in and it works good, just some final tweaking left |
