We had a storm two nights ago with some powerfull winds. Our Dish was loose so it moved. When I tried to find the Nimik 1 (91 deg) I could only seem to find Nimik 2 (82 deg)I have tried several adjustments and still no luck. I am located in ontario canada. My question is is I am facing the sky, what direction am I to ajust the dish to go from 82 degrees to 91 degrees and am I to move the "up down" as well. Please help as I am getting desparate.
go to http://www.dishpointer.com/ and input your location and select the satellite you want. It will calculate your dish elevation and azmuth. Good luck ...
