MDF Cut layout Calc FTMFW.
Username: Van_man
Boston South, MA
Post Number: 4003
Well, Last night I was trying to plan out my cut layout. Spend about a halfassed hour trying to figure out how to get all my pieces from a single 4x8 sheet. I was getting ready to cut little pieces of paper out and stick them to graph paper, lol.. Instead I gave up. So today i dl a program, and in like 5 minutes...
What a time saver.
I still had to do a manual layout, as the program couldnt figure it out.
measurements were deleted to protect the design.
A pic is worth 1000 posts!!
Post Number: 16952
"measurements were deleted to protect the design."
Worried about copyright infringement Marc lol?
How about a link to the program?
Username: Phil_salisbury
Post Number: 684
I don't need no stinkin program to layouts for my cuts.
Username: Van_man
Boston South, MA
Post Number: 4004
Na. its not my design, So I dont want to post someone elses work. Besides, I still owe Phil from Woodlawn, for the plans.
Gee, ya think he would include one with plans? Lol, Just messing Phil.
Oh yea, link to free program.
I dl the executible one.
http://www.delphiforfun.org/Programs/CutList.htm
Post Number: 685
Ahhhh, OK, your using it to plan out the parts I did for the enclosure.
Hey, I did the design for ya, provided spiffying design drawings and gave ya a cut listto boot, what more do ya want.
Username: Van_man
Boston South, MA
Post Number: 4005
well, if nothing else, this thread shows how lazy I am...
Username: Bjfish11
Garden Plain, KS USA
Post Number: 433
How do you plan on cutting that? With a jig saw? LOL. You want be able to make those cuts all the way through on a table saw...
Post Number: 16957
Good point BJ. Most one and done box builders will appreciated that program because it maximizes the sheets' surface and saves them from buying more than they need. Box builders like yourself have scraps from previous jobs that you continually use on future projects, and you know this so maximizing the sheet isn't as important to you. I like having scraps of just about any kind of wood product, just like hardware. Someday I know I'll need it.
Username: Van_man
Boston South, MA
Post Number: 4008
I will hack those out with a skilsaw and skill, Then turn to a table saw to true them.
and true, If i can get away with buying one sheet, I will. I dont use mdf very much, so no sence holding on to scrap pieces.
Username: Bjfish11
Post Number: 434
Actually though Paul, I use a cut sheet program as well. It helps keep costs down ;)
Username: Naledge503
LowDownForum.com
Post Number: 3824
Sorry to jack the thread. BJ, did you get my email today bud?
/thread jack.
Username: Bjfish11
Post Number: 436
Jesse, just responded to it within the last 10 mins ;)
LowDownForum.com
Post Number: 3826
Thank you sir. :-)
Post Number: 686
I don't bother because I been doing this for so d@mn long, I can figure it out in my head what is the best method for cutting materials to get the most gain per sheet and what fall offs I can use for the next project.
While program is good to use to gain the most from the material, especially if the concern not waste more than what is absolutely required, sure, it makes sense to use such a program.
But, for the ease of accuracy and time savings as to the progression of the cuts being made, it matter as time and labor spent vs saving a few pennies.
But that's just me.
