What are ALL the wiring options i have??
Username: 2pacalypse1971
Sandusky, Oh
Post Number: 502
2 single 2 ohm jl w3 12's, waht are ALL the wiring options i have
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2266
Wire in series for a 4ohm load. If you have a 2-channel amp then just wire each sub to one channel, if your amp can handle it.
Username: Insearchofbass
Post Number: 9444
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Sandusky, Oh
Post Number: 503
yeah thanks for the website but that doesn' really help me cuz rockford doesn't have any single 2 ohm subs, can i run this at 1 ohm, or 4 ohms bridged on a 2 channel??
A pic is worth 1000 posts!!
Post Number: 16972
Yes you can run it at 1ohm, as long as the amp can handle it.
Sandusky, Oh
Post Number: 504
alright then thanks alot paul thas all about i need, rockford t5001 here i come i suppose
