I have a 2007 F-150 super crew and I was wondering whether or not I needed to get new speakers if I am going to get two subs and an amp installed in the back or if the stock speakers are alright.
You don't have to get new speakers. Do you dislike the stock ones though? If so, you might wanna look into a new set. If you're happy with them, no reason to look around.
The stock speakers are alright, they just don't put out as much volume as I like but I would like to keep them if it's not a big deal because I am kind of on a tight budget! Thanks for your help!
