Which amp for the cdt CL61-Pro's
Username: Jladam415
Post Number: 45
i dont want to run much if not any bass, i want them as loud as they can be safely, ive seen them rated at 120-150watt rms 4ohm with the tw-25 tweeters
what do you guys recommend for amps, i only need the two channels, and what brands.. if they can take more than rms safely please let me know
thanks
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1725
Kicker 350.4 for budget and quality. Bridge the channels and you'll get 175X2 @4 ohms. Then set your gain properly and it'll be smooth sailing.
Username: Nd4spd18
Northwest PA
Post Number: 6921
http://www.caraudio.com/forum/showthread.php?t=281234
It's still for sale :-)
That is a rare amp with vacuum tube technology that would work great with those speakers
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1736
Wish I hadn't have scrapped mine =(
Username: Jladam415
Post Number: 53
i think i am going to go for the 450.2 kicker... any last words before i do?
Username: Ninobrn99
Honolulu, HI USA
Post Number: 12
cadence zrs 9004
Username: Alteraudiousa
Concord
Post Number: 1626
CL-61Pro's must be from woofersetc.com, if that is so i might come with the satnet 400 crossover which is junk and the power handling is way down on them when using that. they may take 120rms but thats about it. I would say get the regular CL-62 set that comes atleast with the satnet 480 or better yet upgrade the crossover to the 560i for better power handling. What's your price range?
