The 7995 do not have internal Amps, so you will need front, rear, and a subwoofer external Amps to power your speakers.
I really like the CDA-9815.
You can get one for $350.00 "Brand New" on Ebay
Chippa
I have an Eclipse 36401 50Wx4 amp to power my highs so the amp situation is not a problem. I was just wondering if the quality is as good as Alpine claims it to be. Thanks!!!
Hydro
Well Alpine is one of the best if not the best headunit out on the market Ive owned mine for a little over a year and never had any problems
Chippa
Thanks, I've got my CDA-7995 sitting right here waiting to be installed. I will post a review after I install and tweak it this weekend!
