Bronze Member Username: Me123456Post Number: 17 Registered: Apr-08 | hey guys i need some help i plan on getting two JL 13.5 w7 and i want to get some inside speakers i will be able to hear really good even with all that bass.I saw some alpines that look good but i want to know what you think.the car its going in is a 07 monte carlo |
Silver Member Username: ExigeCincinnati Post Number: 331 Registered: Nov-07 | What's your budget? |
Bronze Member Username: Me123456Post Number: 18 Registered: Apr-08 | on the inside speakers no more then $350 |
Silver Member Username: ExigeCincinnati Post Number: 333 Registered: Nov-07 | have you budgeted for an amp and wiring also? |
Bronze Member Username: ClawlessShreveport, La Post Number: 11 Registered: May-08 | fosal has a new component out. I just got it and its the cleanest sounding mids and highs ive ever had. i got them for 269. what amp are you puttn on them? |
Bronze Member Username: Me123456Post Number: 19 Registered: Apr-08 | any amp that will puch them as long as i can hear the music just as good as the bass i know them two w7 gonna hit just dont want to loss my music WHATEVERE IT TAKES!!! |
Bronze Member Username: Me123456Post Number: 20 Registered: Apr-08 | plz help |
Silver Member Username: ExigeCincinnati Post Number: 355 Registered: Nov-07 | regarding your budget....does your budget include money for an amp also, or is it strictly just for speakers? we gotta know this to figure out what will work for you. |
Bronze Member Username: Me123456Post Number: 22 Registered: Apr-08 | whatever it takes money dont matter |
Silver Member Username: ExigeCincinnati Post Number: 368 Registered: Nov-07 | Check your messages man. |
New member Username: Ggs08GA Post Number: 1 Registered: May-08 | if money doesnt matter then this should work great. http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3401\link and these comps are very nice, a friend had a set and they sounded amazing. http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4753 |
Bronze Member Username: Me123456Post Number: 23 Registered: Apr-08 | Thanks jeremy i been looking for some help for a while now |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 377 Registered: Nov-07 | G, check your messages dude. |
Bronze Member Username: Me123456Post Number: 24 Registered: Apr-08 | forget the budget i just need some info thats all if you want me to put it in a budget fine 350 speakers dont worry about the amp thats taken care of just need to know the are some loud speaker that i will hear over the bass with two of them w7's |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 379 Registered: Nov-07 | Speakers depend on the amp. If it's a 50x2 amp...you wouldn't want to run a component set that takes 200w. So let us know what that amp is. PS - Did you already buy your W7's? If so how much did you pay for them? |
Bronze Member Username: Me123456Post Number: 25 Registered: Apr-08 | dude plz just give me chooses thats all i want you tryin to go into to much detail i know i wouldnt want that i gonna get the amp when i know what components im getting so i can match the power they need all i want is some different chooses.no didnt get them yet when i do im getting them for around $600 each |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 380 Registered: Nov-07 | relax man...i'm trying to help you out...but i will quote you from your previous post: "dont worry about the amp thats taken care of" ...now you see why i asked what amp you're using? There's many great options for speakers. If you'd like to look into CDT, I can help you get their top of the line components at a great discount currently. Simply email me at sales@exigeaudio.com if interested. This would be the ES series, and we could tailor the set to fit exactly what you're looking for soundwise. Other good companies include Focal, Dynaudio, and Boston among many others. It's hard to tell you what is the best company to suit your needs unless you tell us what you're looking for besides loud. Every company can get loud...but who can sound good TO YOUR EARS doing it. On this note...would you prefer a brighter or more mellow sound? Strength in the midrange area, or better in the midbass area? Have you thought about a 3-way set for the best of both worlds? Have you given any thought to running your speakers active instead of passive? Though picking out a pair of speakers isn't too hard.... with your budget, give some thought to it. What do you really want besides LOUD speakers? |
Bronze Member Username: Me123456Post Number: 27 Registered: Apr-08 | i have thought about a 3-way but wouldnt that give me more bass?i want speakers that i can hear over all that bass i still sound clear that perrty much it .about that brighter or mellow sound what do you mean about that? |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 384 Registered: Nov-07 | A 3-way set would give you better midbass and midrange by separating the drivers used from a single driver into 2 drivers...a larger one for midbass..a smaller one for midrange. From there you also have the tweeter obviously. Please note...midbass is not the same as sub-bass which is what your JL W7's will be playing. So it'll help out everything above what your subs will be playing. If you don't know the difference between bright and mellow, I would suggest taking a trip to a local car audio store and listening to speakers to find out what you want soundwise. Brighter speakers have more "oomph" in the treble area...something that is too bright (harsh) will come off as ear-piercing to you. A mellower tweeter is a softer tweeter...something that will not get harsh. Typically brighter tweeters have more detail, but there is normally a point where they become too bright. If you're not sure and simply want to play it safe, a silk tweeter is a good choice. Who will be doing your install? A shop? |
New member Username: Basher8621yahoocomBossier City, La USA Post Number: 2 Registered: Apr-08 | I second the 3 way set-up if you have the amp power for it. You can run either a HD 3 way for ES 3 way from CDT. I got my ES 3 way set from Exige and the price was unbeatable with customer service out of this world. |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 391 Registered: Nov-07 | well thank you Steve and welcome to the forums |
New member Username: Basher8621yahoocomMcConnell AFB, Ks USA Post Number: 5 Registered: Apr-08 | Thanks alot. I have been over at SD and couldn't take it there any more. There is one particular mod who is too bias and everyone seems him as a god. I just got tired of it and needed to find a new forum so here I am. |
Bronze Member Username: Me123456Post Number: 28 Registered: Apr-08 | yeah a shop i dont let just anybody put my stuff in im going to the same one that put my last system in its in wisconsin it just suck because im in chicago .i dont want it to sound harsh just want to hear it the word and it sound clear im thinkin about getting the jl audio xr650csi or the zr but they might cost to much .is sound like you work in a shop is there i number i can call to talk to you guys about this? |
New member Username: Basher8621yahoocomMcConnell AFB, Ks USA Post Number: 7 Registered: Apr-08 | I just PMed you. CDT speakers sound amazing to me. I would change nothing about them. I am not a big fan of JL. They do sound good when installed right, just like every other speaker. I just feel there is better for the money. |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 393 Registered: Nov-07 | G, my email address is sales@exigeaudio.com. I can help you find a good shop closer to you. Email me and I'll get you my personal contact info as well. Personal=personal cell, not just regular number, therefore I don't want to post that publicly where it could get abused. Email me and I'd be happy to help you out. |
Bronze Member Username: Me123456Post Number: 29 Registered: Apr-08 | i sent you a message |
Silver Member Username: ExigeCDT, Audiopulse Dealer Post Number: 395 Registered: Nov-07 | Replied. |
