Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 397 Registered: May-07 | I am looking to replace my 2-12" Solo X's(require too much room for my Jeep) with 2 subs that will be happy with about 7.5-8 cu. ft total. SPL or SQL setup prefered. 12's or 15"s. They will be run off of 2- BXI2005D's (I know, I know) for now. I would like to get better TL #'s if I can.. Electrical is set for these amps.. Going in my 1999 Jeep Cherokee later this summer. Please leave any suggestions and I will do the research on the sub's that I am not familiar with.. If the amps are not enough power for the subs that yall recomend, It will be fine as I will upgrade when time is right... Thanks a lot guys! Budget is not real important. |
Silver Member Username: ExigeCincinnati Post Number: 349 Registered: Nov-07 | Budget is not real important until you realize what all is on the market ;) I would suggest just giving us a baseline to work with. If there was truly no budget, I'd tell you Audiopulse LMS Ultra's at $1400 retail per sub...see my point? |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 399 Registered: May-07 | Audiopulse LMS ULTRA are not outta the question... But I thought they required more room(then I have) for max performance.. But I figured I would get called on the budget... so I'll go with $1200 or so.. Will look into ALL suggestions! thanks Exige Audio for the reply |
Silver Member Username: ExigeCincinnati Post Number: 350 Registered: Nov-07 | 2 ULTRA's actually need a max of 7 cu ft ported. 2 Audiopulse Axis 15's would work with your budget and available box size. Feel free to email me if interested. Mike sales@exigeaudio.com |
Bronze Member Username: GibsonguyPost Number: 41 Registered: May-08 | what exactly does a $1400 sub look like? do you have a link to this sub you speak of? |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 401 Registered: May-07 | http://www.audiopulse.com/products/subwoofer-drivers/lms-ultra |
Gold Member Username: Drant19DUB-C, TX Post Number: 1001 Registered: Aug-07 | i clicked the link and almost came...thats how good that sub looks |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 4023 Registered: Dec-06 | No Abarca... that's how long you've been without püssy |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 402 Registered: May-07 | lol ... Those are NICE fu(kin' subs... Never heard the 15" Axis's either... Anyone using them? 2-15 Fi Btl's 2-Treo SSX 15" these were suggested by local buddies but still concerned with space. still need suggestions... 8 cu. or less |
Gold Member Username: CtmikeCt. Post Number: 6168 Registered: Feb-06 | incriminator audio dp mach 5 spl |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 403 Registered: May-07 | thanks ctmike.. Will look into those.. please keep going guys! |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 2768 Registered: Jul-05 | If im correct those amps only put out like 1600rms @ 1ohm so get 2 15" RD audio Alphas for a nice little SQL setup. I dont think you have enough power to properly push an Axis, BTL, or SSX. |
Bronze Member Username: GibsonguyPost Number: 42 Registered: May-08 | Those axis subs look nice, but I can't see paying that high price tag. I could see them selling for close to $1000 each, but $1400 seems like a lot to me. But for people where money isn't an option they would be cool to try out. |
Silver Member Username: ExigeCincinnati Post Number: 351 Registered: Nov-07 | "lol ... Those are NICE fu(kin' subs... Never heard the 15" Axis's either... Anyone using them? " Here's one guy who will be using it shortly. http://www.caraudio.com/forum/showthread.php?t=318302&highlight=audiopulse One of the posts in the thread though says quite a bit about the sub though .... http://www.caraudio.com/forum/showpost.php?p=4691548&postcount=39 |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 404 Registered: May-07 | i dont mind under powering the subs a lil'. The amps will be replaced with about 4400-5000 wrms eventually.. I really need to free up space in my jeep. But was happy with the loudness of my Solo's 12 cu. ft.... No back seats |
Bronze Member Username: GibsonguyPost Number: 43 Registered: May-08 | What buildhouse do they use for the axis subwoofers? It looks like something TC Sounds would come out with. Just another LMS type driver. |
Bronze Member Username: GibsonguyPost Number: 44 Registered: May-08 | o wait just checkout out tc's site lol. http://www.tcsounds.com/ question answered. |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 405 Registered: May-07 | it is made by TC sounds-Audiopulse |
Gold Member Username: HdubbTeam Revolution Post Number: 3697 Registered: Nov-04 | hmm the ssx would be a great sub in my opinion. also the hw v.2 would be a great sub for you. the new btl would be cool. even though i havent played with them, but if they are better then the v.1 then im sure they are badass. the re mt, is another great choice. lol the axis isnt a lms driver. its a normal flatwind alum coil. that uses a 3hp motor. the lms coil is only used in the lms ultra, and lms5400. and quite a few older 3in subs. like the rls which is a modded 3hp motor. another slug was added to it. |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 406 Registered: May-07 | "Here's one guy who will be using it shortly." The amp he is using is likely what I will be upgrading to I plan to use 2- AQ2200D |
Bronze Member Username: GibsonguyPost Number: 45 Registered: May-08 | just wondering, but what type of electrical system do you have? You do know it will cost close to a grand in electrical upgrades to run around 5000rms? Just something to consider when picking out subs. |
Gold Member Username: Naledge503Portland, Or Post Number: 3726 Registered: Jun-06 | "just wondering, but what type of electrical system do you have? You do know it will cost close to a grand in electrical upgrades to run around 5000rms? Just something to consider when picking out subs" |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 407 Registered: May-07 | it's all in my profile GibsonGuy. I've got a good foundation to start with... |
Bronze Member Username: GibsonguyPost Number: 46 Registered: May-08 | i did read the thread. all he said was it was set, but i wasnt sure if he knew what set was. and mark, thanks for suggesting i check your profile. looks like you're good |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 408 Registered: May-07 | Not a problem GibsonGuy.. Bump for more suggestions! |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 411 Registered: May-07 | bump |
Gold Member Username: 04redmach1Columbus, GA USA Post Number: 1994 Registered: Mar-06 | We could build you a nice flat wound version of an Alpha 15 if wanted Not many of those out there yet, and a custom build. Will handle the 5K for later down the road as well. Kevin lowhz01@yahoo.com |
