Bronze Member Username: SlivdoggSt.ignace, Mi United states Post Number: 11 Registered: Jun-08 | i want a good mtx amp for theses 2 subs... im going all mtx! can someone give me some suggestions? http://sonicelectronix.com/item_2239_MTX+Audio+T7512-44.html |
Gold Member Username: Nd4spd18Northwest PA Post Number: 7614 Registered: Jul-06 | I can give you a suggestion, don't buy an mtx amp. Or sub. |
Bronze Member Username: SlivdoggSt.ignace, Mi United states Post Number: 13 Registered: Jun-08 | why? |
Gold Member Username: CtmikeCt. Post Number: 6219 Registered: Feb-06 | because there's better that you can get for the same amount you'd spend on mtx. |
Bronze Member Username: SlivdoggSt.ignace, Mi United states Post Number: 14 Registered: Jun-08 | ok well should i get a kicker set then? |
Gold Member Username: CtmikeCt. Post Number: 6222 Registered: Feb-06 | are you dead set on buying from circuit city or something? what are you looking for in your system. |
Bronze Member Username: SlivdoggSt.ignace, Mi United states Post Number: 15 Registered: Jun-08 | ok this is what i want... i want a ststem you can hear from like a mile away...but yet at the same time sound great. rite now i have a chevy silverado and i dnt wanna buy a new alt. so i wanna be able to use what i have now without buying more stuff? and im thinking about 2 kicker cvx 12".... but id what amp to get...any suggestions? ill take any? |
Gold Member Username: CtmikeCt. Post Number: 6224 Registered: Feb-06 | the cvxs' are nice subs. not worth msrp, but if buying from online you can get them at a decent price. not sure on your alt. but those subs are going to want 1500w+ for the pair, so not sure if your charging system is up to handle that much. but if you can i'd personlly pick up a sundown saz1500d and run the pair at 1ohm (so make sure the subs are dual 4ohm vc). |
Bronze Member Username: SlivdoggSt.ignace, Mi United states Post Number: 16 Registered: Jun-08 | what amp should i get the mtx or hifonix? http://sonicelectronix.com/item_5645_--+CRAZY+DEAL--+--+MTX+Audio+TA7801+Thunder +7801.html http://sonicelectronix.com/item_12211_Hifonics+BXi+1608D.html |
Silver Member Username: Snowball123West Allis, WI United States Post Number: 800 Registered: Oct-07 | .... |
Gold Member Username: Drant19DUB-C, TX Post Number: 1025 Registered: Aug-07 | whats your budget for amp and subs? |
Bronze Member Username: SlivdoggSt.ignace, Mi United states Post Number: 19 Registered: Jun-08 | ok my decision is made im gettin 2 mtx 7500s with a mtx mono amp |
Gold Member Username: Drant19DUB-C, TX Post Number: 1026 Registered: Aug-07 | if you were to go with just 1 brand...i would have picked differently than MTX. MTX isnt that good IMO |
Bronze Member Username: SlivdoggSt.ignace, Mi United states Post Number: 23 Registered: Jun-08 | ok then what would u go with? |
Gold Member Username: Drant19DUB-C, TX Post Number: 1028 Registered: Aug-07 | whats your budget? |
Bronze Member Username: SlivdoggSt.ignace, Mi United states Post Number: 41 Registered: Jun-08 | my budget is $600 |
New member Username: Mario_silvaCOATZACOALCOS, VERACRUZ MEXICO Post Number: 9 Registered: Jun-08 | http://www.ikesound.com/product-product_id/6624 Check this out... |
New member Username: Mario_silvaCOATZACOALCOS, VERACRUZ MEXICO Post Number: 10 Registered: Jun-08 | And this... http://www.ikesound.com/product-product_id/5551 |
Bronze Member Username: Mario_silvaCOATZACOALCOS, VERACRUZ MEXICO Post Number: 11 Registered: Jun-08 | i just foud this, very good deal for a good quality sub... http://www.ikesound.com/product-product_id/7348 |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 5358 Registered: Dec-05 | Why don't you talk to kevin holden, he can hook you up with some great stuffs and 600$ is a very decent amount. IMO forget about MTX and get quality stuffs |
