Budget system
Username: Rds2oo8
MN
Post Number: 245
for about $800 looking for sq type system 2 12s or 1 15 amp box wiring head unit all included throw out some ideas plz
Username: Howtoeatapencil
Post Number: 125
Ask kevin holden, im sure he can find something nice for you
Username: Ctmike
Ct.
Post Number: 6183
not that big of a budget for everything. you could buy my 15" aa atlas for cheap to start with:-) very nice sq sub that doesn't need alot of power.
Username: Ggs08
GA
Sub $188
http://cgi.ebay.com/NEW-RE-AUDIO-SE15D4-15-1200w-COMPETITION-CAR-SUBWOOFER_W0QQi temZ280231795782QQihZ018QQcategoryZ18804QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Amp $200
http://cgi.ebay.com/NEW-KICKER-ZX750-1-MONO-CLASS-D-AMPLIFIER-06ZX750-1_W0QQitem Z180247137361QQihZ008QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Amp kit $46
http://cgi.ebay.com/PHOENIX-GOLD-AKIT42-4-GAUGE-COMPLETE-CAR-AMP-WIRING-KIT_W0QQ itemZ360055852354QQihZ023QQcategoryZ71528QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
HU $150
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6197
and you could build your own box for about $40 which would put just over $600
Username: Hurricanebr1an
Western Burbs of Chicago, IL Usa
Post Number: 551
15" FI Q Dual 1 ohm $280ish
Kicker zx750.1 refurbished $200ish
Fishercustoms box $150ish
4 Ga amp kit $50ish
$120 left for a H/U...pioneer or alpine
And Robert quick note of advice if you want good SQ make sure you lay some sound deadener.
Username: Insearchofbass
Post Number: 9336
Im not sure id recommend a pioneer headunit unless they have worked out the rca grounding issue
Username: James1115
Use a simple...
Post Number: 10627
I would buy Mike's atlas to start and build from there. Can you build your own box? 2.5 sealed would be perfect for it, ask Mike louden if he still has the box that I built for my avalanche and see if he will sell it to you cheap. Get a 300 watt amp at 4 ohms and a cheap cd player for $200 or so on ebay(look alpine) then grab a 4 guage amp kit for like $50. You don't need a 4 guage amp kit with only 300 watts but I would do it anyways because you will prob upgrade in the future and you dont want to have to rewire.
Post Number: 552
"Im not sure id recommend a pioneer headunit unless they have worked out the rca grounding issue"
didnt even know there was a problem
Username: Waresgaragestereo
Fort Valley, GA
Post Number: 185
yeah pioneer sux bad.
i have a pioneer hu that was given to me. i cant use with my system cuz it keeps cutting off on low notes. i bought a JVC from my brother and its awesome! nop pioneer radios or amps. idk about their speakers
Username: 04redmach1
Columbus, GA USA
Post Number: 1998
I do have something that would work for you, and leave enough money to either build your own box, or have one built. Would include an Eclipse headunit :-) Shoot me an email.
Kevin
lowhz01@yahoo.com
Username: Snowball123
West Allis, WI United States
Post Number: 779
get premier not pioneer.
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2247
It's the same thing.^^^^
Post Number: 780
well id rather have premier than pioneer. havent had problems with mine.
Username: Drant19
DUB-C, TX
Post Number: 1016
i have a premier 780mp and had the rca grounding problem. i wont buy another pioneer/premier again.
ALPINE HUs!
