Silver Member Username: Dirtrider125Post Number: 182 Registered: Apr-07 | if you do this will it sound better than a pre made ported box? im not making the whole box i figured this would be the same thing ill get these from ebay http://cgi.ebay.com/3-INCH-SPEAKER-BOX-PORT-FOR-SUBWOOFER-BOXES-CAR-AUDIO_W0QQit emZ260243254111QQihZ016QQcategoryZ67773QQssPageNameZWDVWQQrdZ1QQcmdZViewItem and just put them on a sealed box |
Diamond Member Username: BestmankindPost Number: 20953 Registered: Oct-05 | you can't just stick a port on a sealed box. sealed boxes don't have sufficient volume. |
Silver Member Username: Dirtrider125Post Number: 184 Registered: Apr-07 | i calculated it out i found one that is 1.6 cubic feet and the recommended ported box volume is 1-1.75 would it work if the volume and everything is right |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8101 Registered: Jul-06 | Sure go ahead and try it. At worst you've ruined a cheaply made enclosure and wasted a little money. You could have a ported box built to spec which would be the smart thing to do though... |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 383 Registered: May-07 | Wht do people try to get around doing things correctly... I will never understand that! |
Gold Member Username: Crayola0Portage, Wisconsin Post Number: 2404 Registered: Jun-06 | ill put my vote to laziness lol |
