Gold Member Username: Killerzracing71Post Number: 2203 Registered: Aug-05 | http://s45.photobucket.com/albums/f92/RyanM923/RandomBoxDesigns/?action=view&cur rent=QuadMach5MZs18ft3at28hz.png I have a max of 47" seat to tailgate in my wagon Leaving me 2" to work with will it be okay like that with the port firing reward that close |
Gold Member Username: InsearchofbassPost Number: 9315 Registered: Jun-04 | no thats too close |
Gold Member Username: BernymacCambodia Post Number: 3984 Registered: Sep-04 | your title sounds dirty. Like I said, port up since you don't have enough space from box to tailgate. |
Silver Member Username: Dsmith07NC Http://com4.... Post Number: 829 Registered: Jun-06 | Thats definetly no bueno. |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 5176 Registered: Nov-05 | cut the box size down enough to fit all the subs then run 5-6 4" aeros.. should be fine then with that setup you'd need 5" from the back of the box to your rear |
