Accuracy
Username: Palewhiteboy
BC Canada
they say that ported and bandpass boxes arent as "accurate" as sealed but do they mean accurate as in the note of the bass or the timing of the note being played?
Username: Dirtrider125
Post Number: 167
they dont sound as clean but they louder
BC Canada
would a sealed still belt out pounding lows without being ridiculously large?
Username: Tejcurrent
Post Number: 1363
Still depends on vehicle, enclosure, sub(s) and power.
Username: Naledge503
Portland, Or
Post Number: 3683
A ported enclosure when built properly can sound as good as a sealed enclosure.
When I speak in terms of accuracy, it is the timing of the note or how precise the sub is playing the note without hesitating, or missing it.
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 2101
its how well the enclosure is designed/built.the so called boomy sound from ported boxes is cuz of prefab ported boxes if ya want my opinion
Username: Skibum12189
Cleveland
Post Number: 2893
with my current sub, i went ported (my first ported setup) and i love it. the sub is probably a step up from the others i've owned, but it's just as clean as any other. my buddy's ported w7 is the same. both are clean and loud. ive never heard my current sub sealed, but it always seemed to me that the my previous subs always sounded as if they couldn't breath sealed.
build a smaller ported box (to specs) and you should be able to maintain a nice balance of sq and spl
