Pioneer Premier TS-W3001D4 12" subs
Username: 71_chevelle
I was wondering if i got a pair of Pioneer Premier TS-W3001D4 12" subs would two Alpine PDX-1.1000 amps be sufficient to run them? one for each sub since each sub RMS at 1000 watts
Username: 420alldaylong
Post Number: 3618
just fine ^^^
But I would go with one amp on the subs.
I like these subs had one of the dual 2ohm version on 1500RMS and it sound good.
Ok. And what amp do you suggest i should get to power a pair of premiers?
Post Number: 3620
Whats your budget?
probably upwards to around 800
because i can get the two Alpine PDX-1.1000 for 400 each unless you can find them cheaper?
Post Number: 3621
http://www.audioque.com/aq/AQamps2200D.htm
Good subs to.^^^^^
ok and it says 2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
what does linked power mean?
Post Number: 3622
Thats for 2 of those amps together.(combined power)
You only need 1 AQ2200D for what you got.
Post Number: 7
oh ok sweet!! thank you very much!!!
Username: Rovin
Post Number: 13811
just saved urself a crapload of $ by coming to ecoustics ....
Username: Somedonniedude
Illinois United States
Post Number: 1589
"what does linked power mean?"
2 amps strapped/connected together, acting as a single amp.
Post Number: 9
is it possible to strap two Alpine PDX-1.1000 amps together so they would act as one amp?
Username: Kpa2727
Old Bridge, NJ USA !
Post Number: 1294
hunter man these are some locals of the forum. listen to them you can get way better then just the pdx's. also the subs idk for the price you could prob do better to.
Username: Skibum12189
Cleveland
Post Number: 2897
yea hate to be an azz, but i personally owned a pioneer tsw3004 and had it on 1000 watts....i was totally disappointed. you're gettin ready to throw some big money down and i honestly feel those subs aren't right for you. they totally lack in sq and don't have a ton of spl.
much better out there fyi
Username: Rovin
Post Number: 13816
not sure on this current model but something that some ppl dont know about pioneer subs is that their 1000wrms sub they need considerably bigger boxes than rec for it to hit the lows good & they do pound pretty good for its price range but id rec a RE SX for more SQ over it anyday...
Post Number: 24
ok thank you guys! i'll look into an AQ2200 and the RE SX. thank you for helping me out before i totally shot myself in the foot! how much do the RE SX 12" run? and what size of the RE SX would you recommend? i only said 12" because thats what i was told was a good size condsidering i like to listen to a combo of rap and classic rock.
Cleveland
Post Number: 2899
2x
http://cgi.ebay.com/NEW-RE-AUDIO-SE12D4-12-1200w-COMPETITION-CAR-SUBWOOFER_W0QQi temZ300227524545QQihZ020QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
1x
http://www.edesignaudio.com/product_info.php?cPath=1_22&products_id=44
^^(can find a better price on teh nine.1 used if you look)
alot of people might choose the AQ 1200d over the nine.1.....i, however, have never used the AQ 1200d but i can tell you i really like the nine.1 and, contary to common belief, i found that ED had awesome customer service!
Post Number: 26
Thankz cal!
and i was wondering if i need an amp that puts out 1000 watt rms at 2 ohms if my subs are rated at 2 ohms or can it be one ohm? thats where i'm getting kind of confused.
