I have a 94 Jeep Cherokee. I have a set of CDT 61a t25. Right now the tweeter is mounted in the middle of the woofer. Ive been thinking that maybe I should mount them elsewhere. Where would you all suggest? The apillar is open, there is a spot right next to the door handle where the power lock switches would go if it had them from the factory, i could also drill a hole into the door as well.
If you wanna change them around, start with the spots that are open before you drill into anything. See how they sound there and then decide if you want to continue moving them.
