Re audio
Username: Clawless
Shreveport, La
Post Number: 13
are these subs any good? I have a friend thats lookn to buy them. Hes debating on the se 12 or the memphis m3 mojo. I dont know much about either.
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5110
RE makes great subs.. I've ran two RE SX 15"s for 2 yrs with no problem.. took more than double rated power daily
also running an RE XXX 15" currently
Username: Loc_out
SOCAL2 RE 15 XXX
Post Number: 2104
Craig the SE is 600RMS the mojo 1000RMS.
You should look into the SX or XXX.
Username: Frkkevin
Post Number: 5113
.. or two SEs.. friend ran two and it slammed
Username: Clawless
Shreveport, La
Post Number: 14
Which sounds better? they will be ran off of two kicker 1000x1s.
Username: Drant19
DUB-C, TX
Post Number: 962
wheres the best place to buy re audio subs?
Username: Rovin
Post Number: 13785
''''.. or two SEs.. friend ran two and it slammed''''
^^^12s ???
as said above RE makes excellent products - did a 1 10 SX box for some1 last wk & output & SQ was sweet ! ...
Username: 420alldaylong
Post Number: 3609
If your looking at RE don't forget about Fi. Fi BL,Q's love 1000RMS each
Ficaraudio.com
Post Number: 3610
Install and enclosure are very important.
Username: Frkkevin
Post Number: 5114
honestly.. best place for new RE subs is ebay lol
check caraudio.com for the classifieds
and yes my friend ran the 12" SEs.. also got on friend running a single SX 12" which will surprise you and another running a single SX 18" which just hurts in his truck
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 291
Re Se can handle a lot of power Quentin had is on a hifonics bxi 1500d and they took that all day long with no problems and to this day still on that amp
Post Number: 3613
KT
Is that 1 BXi 1500d for both RE SE's or 1 for each sub.
If its one for the pair of RE SE's then the RMS is about rite on.(hifonics BXi do around 80% of rated power so that would be about rite.
And yes good companys that makes subs can handle more RMS the rated. But the power has to be UNCLIPPED.
Username: Rovin
Post Number: 13788
yeah im looking at 2 10s SE as my next set for daily sql ...
Username: Frkkevin
Post Number: 5115
you won't be disappointed :-)
Username: Frkkevin
Post Number: 5116
Username: Loc_out
SOCAL2 RE 15 XXX
Post Number: 2106
If your going to run it off 1000RMS. Go with two SE.
Username: Neyetmare
Post Number: 17
I have been looking at getting four 12's i have come down to either re se's or rd sonances. which one would be better?
Username: Frkkevin
Post Number: 5136
never heard the sonances.. they could be a better option but from all the RE SE installs I've heard.. i was impressed with every install.. they really wang
Username: Neyetmare
Post Number: 18
Ya, i have been thinkin of choosing the se's cus ive never heard them sound bad, ive always been amazed. Have you heard any rd subs? i have heard the sonance and the aplpha and wasnt to impressed, but the guy who installed them didnt really know what he was doing.
Username: Kingandsons07
Lincoln, NE TEAM RD U.S.A
Post Number: 960
Logan put 1750 on one SE if i remember right
Username: Frkkevin
Post Number: 5143
I've never heard an RD subs, and install is key. Would be nice to do a side by side test
Username: Neyetmare
Post Number: 19
Was it a burp, or do you mean he put 750?
Username: Frkkevin
Post Number: 5145
logan ran 1750 daily :-)
Username: Neyetmare
Post Number: 20
thats insane. i never woulda thought an se could handle that. I guess i made up my mind
Post Number: 3624
You have to know what you are doing when it comes to what Jack and Quentin are saying.
If you are trying to run that much power go with RE SX's.
Post Number: 961
yep daily and the sx are real nice subs they start shining i say 1200rms any way you go they are all nice subs
Username: Neyetmare
Post Number: 21
I'm not looking to run one sub at that, i was just gonna run four se's at 3000 watts, i was a little worried that they couldn't handle that but i guess it'll be fine.
Username: Safe_cracker
Chicago, IL US
Post Number: 4552
I ran a RE SX at 2400 rms which was more like 2920 (both strapped amps 1460rms each birhtsheet) for over a year and sold it to Kevin which ran it for ???? Polo..
Chicago, IL US
Post Number: 4553
Oh and the amps rated power was at 2ohms (2x Kicker sx1250.1) BUT I had dual 1ohm subs, ran the amps at 1ohm so power was a bit higher... :-O .. Polo.
