Bronze Member Username: HyloPost Number: 50 Registered: May-06 | If I install diplexers and use single cable run for OTA antenna and dish, will it work? |
Silver Member Username: AbjPost Number: 599 Registered: Feb-06 | yes it will work but you need to have 2 diplexer. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 2772 Registered: Oct-06 | This is how it will look like: ![]() Reference: https://www.ecoustics.com/electronics/forum/home-video/330353.html |
Silver Member Username: AbjPost Number: 602 Registered: Feb-06 | just remember if you are using disq. switch. hook up all the lines to disq. switch first than you take the out port from disq. switch to sat. port on diplexer. |
Silver Member Username: AbjPost Number: 603 Registered: Feb-06 | also after you hook up everything and if you want to watch t.v from OTA, you have to turn your box off, so it will not interfere with signal.. |
Bronze Member Username: HyloPost Number: 51 Registered: May-06 | thanks guys! appriciate your help! |
New member Username: ChapmanPost Number: 6 Registered: Nov-07 | Hi, will this same setup work for cable tv and satellite, instead of the OTA feed? The photo illustrated cable/antenna, but I just want to make sure it will work for the cable. Thanks |
Silver Member Username: AbjPost Number: 608 Registered: Feb-06 | yes it will work with cable. just oonnect the cable to Ant. side ... This is the way I have hook up to now. I use it when the dish is down ...or bad weather and losing signal ... |
Silver Member Username: DimwittPost Number: 722 Registered: Aug-06 | I never had any luck with diplexers and OTA w/100' cable run. probably did something wrong -- although it worked on a shorter test run. |
