HELP with pansat 2700a no picture
Username: Kildonan
Philadelpia, Pa Usa
Post Number: 45
I downloaded the 269 bin all the channels come down but no picture unit keeps waiting for picture to 600 percent, then it says no signal, scrambled or bad channel. Sometimes the pictures comes in briefly for a few minutes, then freezes then is lost.
Tried everything my limited knowledge of FTA affords with no results help please?
someone thank you
Username: Metallica
Post Number: 732
Try a hard-reboot..turn on and off from the back of your box..
Username: Kildonan
Philadelpia, Pa Usa
Post Number: 46
Met, tried the hard reboot to no avail, any other suggestions?
Username: Dimwitt
Post Number: 720
for dn reload 268 and see if symptoms still exist.
Username: Kildonan
Philadelpia, Pa Usa
Post Number: 47
thanks will try that, anyone else with any good suggestions?
Username: Kildonan
Philadelpia, Pa Usa
Post Number: 48
Reloaded 268 bin to no avail,anyone else alittle more insight to help me with my pansat 2700a ,still can't get any picture keeps auto rolling saying looking for picture up to 600 percent then no signal or scrambled or bad channel. Sometimes the picture comes up but then freezes and the picture is lost. Help please?!
Username: Dimwitt
Post Number: 721
*edit
GOOD LUCK.
