Nalin can you help
Username: Csb3
Post Number: 21
i don't trust anyone else,is there a new bin for the 2500 to 2700 clone
Username: Doreenakadj
Ontario Canada
Post Number: 1680
yes there is a new bin 268 I checked Nalins site but nothing new added as of yet sorry. but you could get the 268 file from another site of your choosing.
Username: Lklives
Post Number: 15778
U can ALWAYS trust the ones I post ...at dsscommunity and dsscentral
Username: Nydas
Post Number: 10791
Version 268
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
Either b75 or PUFF
http://public.box.net/2500_full_kit
You must select whether you want to have the old b75 files or PUFF files.
If you have b75 boot and want to use the PUFF BINs , you must convert to PUFF boot
If you have PUFF boot and want to use th eb75 version, you must convert to b-75 boot
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Username: Dawood
cb3, You are absoultly right Nalin is a very trusted person here and trust her more than any one. Thanks Nalin.
Username: Csb3
Post Number: 22
thanks nalin. everything works
Username: Hotrod3_652000
Dallas, Tx Usa
i just got my new veiwsat 2000 platinium in how do i get started plz help
Username: Nydas
Post Number: 10808
Join
[link removed]
Joining is free.
Go to:
[link removed]
and in the header part you will find section of files to for getting started.
There are similar facilities at many other sites.
[link removed]
http://www.totalfta*com
