Alpine type r
Username: Loudgangsta
are these subs any good?
i was googling it and came across this site.
also i will be using a 1200watt sony amp to power 2 12 inch alpines.
Username: Hittin1
LakeCharles LA., La
Post Number: 329
Very decent sub with custom enclosure... install is important..
do yourself a favor and get a better amp.
sony sub/amp = sh!t
thank you mark. what amp would you suggest? i don't want to spend more than $300 on a amp.
Username: Insearchofbass
Post Number: 9264
get the audioque 1200.1 and buy the dual 4 ohm alpines and run them at 1 ohm www.audioque.com
Username: Hittin1
LakeCharles LA., La
Post Number: 330
my suggestions:
get 2 subs each with dual 4 ohm voice coils.
1)Audioque AQ1200d-- $250+shipping
2)Memphis PR1000.1D-- Iget em for $250 locally
With the AQ1200 U will likely need to back off the gain a lil. as that amp is underrated
the type r's can and will handle more power than they are rated for even for daily use!
as for the memphis pr1000... I own 4 of them and have NEVER had a single problem with a single one. They are very strong as well. both amps are 1 ohm stable. KEEP IN MIND THAT YOU WILL NEED TO HAVE AN ENCLOSURE MADE TO SPECS FOR THOSE SUBS TO GET THE BEST SOUND.I hope this helps.
p.s.
ok i never heard of audioque but i have heard of memphis. also what do you mean by "dual 4ohm voice coils"?
Post Number: 9265
audioque is a good company its a sub division of digital designs...id pick that over the memphis amp myself....plus dj of audioque gives great customer service and should you have any problems you can count on him
Username: Snowball123
West Allis, WI United States
Post Number: 677
x2. audioque's great.
Username: Mike11202
DD9515G VFL 200.1 = : , Sewell, NJ US
Post Number: 1720
have you bought anything yet?
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2194
I think Sean meant to put this up:
(aq1200)
Username: Mike11202
Post Number: 1721
Subs: (2) Kicker 10" L7 (08 edition)
http://cgi.ebay.com/08-KICKER-L7-Sub-Solobaric-Subwoofer-08S10L7-Solo-baric_W0QQ itemZ380027970940QQihZ025QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Amp: Kicker ZX1000.1
http://cgi.ebay.com/BRAND-NEW-KICKER-ZX1000-1-CLASS-D-SUBWOOFER-AMPLIFIER_W0QQit emZ170219510824QQihZ007QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Hittin1
LakeCharles LA., La
Post Number: 332
the AQ1200D would EASILY be my 1st choice.
www.audioque.com
"also what do you mean by "dual 4ohm voice coils"?"
awww dude..
Where to start..
The subs are are refering to are "dual Voice coils" as well as most subs. Each sub will have 2 pos (+) and 2 Neg. (-) speakerwire connections..The subs you are refering to can be bought with 2 0r 4 ohm voice coils. For the amps that we recomended you would need to order the 4 ohm V.C. You would wire them in parallel all the way to the amp to achieve a 1 ohm load to get maximum power for the amp.
ohm = resistance
Need more info google any of the terms and you will get plenty if info. good luck
Post Number: 9267
I did have the audioque 1200.1 internal pic up but I decided to delete my original post because the amp I found from memphis wasnt the Memphis PR1000.1D so I figured it wouldnt be fair to post the memphis internal pic against it when it was the 1500 watt version...bottom line 1000 watts rms to 1200 watts rms pretty much explains which amp is better for about the same money
Username: Hittin1
LakeCharles LA., La
Post Number: 333
do not get the L7's
the 2- 12" tpye r's will get louder than the 10" L7's and def sound better..
mark thanks. i think i got it. so you are telling me to get 2 subs that are dual 4ohms.
also where can i buy this audioque amp? it must be good for you guys to keep recomending it.
Post Number: 9268
www.audioque.com and click on the order link at the top of the page
Username: Mike11202
Post Number: 1722
"do not get the L7's
the 2- 12" tpye r's will get louder than the 10" L7's and def sound better.."
thats where your wrong
the new L7's will sound better than the Type R (i have owned/heard both)
if comparing size to size the L7 will also get louder
assuming he had stock electrical and a trunk car is why i recommended the 10" L7's with the ZX1000
i drive a 2007 acura rdx
Username: Mike11202
RE MT 15 VFL 200.1 , Sewell, NJ US
Post Number: 1723
in that case i think you should go with the audioque since your alternator can handle it
you should get the new L7 12's over the type r though, louder and sound better
Username: Drant19
DUB-C, TX
Post Number: 970
L7's sound better than a type-r...i dont believe it. all the L7s ive heard just get loud and sound like complete crap.
type-rs however, always get loud and have pretty decent SQ
Username: Hittin1
LakeCharles LA., La
Post Number: 334
i own 2 L5's, I have owneded 2-L7's I also have 2- Solo x's. I havn't heard the "newest" L7's, but by the track record I would say that the 2-12" type r's would sound a lot better than 2-10" L7's. JMHO
Username: Nd4spd18
Northwest PA
Post Number: 7553
Agreed I have NEVER heard an L7 sound good.
Username: Mike11202
Post Number: 1724
I guess when an L7 won an SQ competition it didnt sound good either
Give me a break you guys hear L7's in NOOB installs which is the answer to your questions
You all b1tch about it sounding like crap because your buddies buy them from chain stores and put them in shitty pre-fab boxes
A friend of mine got a proper box off of Fisher Customs for his 15 L7 and it sounded much better than my Type R in Fisher Customs box
Username: Hittin1
LakeCharles LA., La
Post Number: 341
sorry for repeating this but.... 2- 12" typr r. Will get louder and sound better than 2- 10" L7 IMO.
I own 4 solo's and like em a lot but....
Username: Mike11202
Post Number: 1725
Look above I said SIZE FOR SIZE L7 will be louder which is true because of the cone area.
Also notice none of you have heard an 08 L7 so don't come back at me until you have }
Username: Hittin1
LakeCharles LA., La
Post Number: 342
Alpine type r
Notice name of thread..lol
Mike... you are preaching to the choir bro... Very few can stand the mention of the "square" subs. Was being realistic and giving an opinion.
Fu(k it.... BANG EM IF YA GOT EM.... lol I DO!
Diamond Member
Post Number: 20891
mike is a very credible guy. if he says the new L7 sounds good then i believe him. :-)
Username: Hittin1
LakeCharles LA., La
Post Number: 346
Well if mike AND Chad Lee will vouch for em....i'ma go ahaed and say it..... I GOTTA GET 4 OF EM!!
lol
J/K guys
Diamond Member
Post Number: 20892
lol mark. you're a very credible guy yourself. :-)
Username: Hittin1
LakeCharles LA., La
Post Number: 347
Diamond Member
Post Number: 20893
mark brockmanUpload
Username: Loudon
Post Number: 2435
i loved the way my old l7s sounded and they hammered :-)
Username: Ctmike
Ct.
Post Number: 6123
hey mark, want to sell me one of the l5s' you have?
Username: Hittin1
LakeCharles LA., La
Post Number: 349
not really bro... sorry.. I might come off my solo x's for the right price!
Already moved the L5's to my old lady's ride..
Username: Ctmike
Ct.
Post Number: 6124
no need for the solo x, thanks anyways.
