CDT CL61a not enough...what to upgrade to?
Username: Ninobrn99
Honolulu, HI USA
Post Number: 13
My CDTs just arent loud enough and the tweeters arent bright enough for me. What would you all recommend to upgrade to? I have a cadence zrs 9004 that Im using now. Its 250x2rms@4ohm bridged and 90x4@4ohm normal. I dont think id wanna spend more than $350.
Username: Exige
Cincinnati
Post Number: 340
I PM'ed you back Nino....you must not have gotten it? Anyways, we've got some crazy deals on ES-62i sets right now. With an aluminum or titanium tweeter you'd be set to go. Just get back to me when you get a chance and I'd be happy to help you out.
Mike
sales@exigeaudio.com
Username: Ninobrn99
Honolulu, HI USA
Post Number: 14
Mike,
I just looked up the price on a few other sites and even at $500 they're out of my price range. I saw a pair of Polks at Circuit city that sounded much better than what Ive got now. Im actually just disappointed with my CLs
Username: Exige
Cincinnati
Post Number: 342
emailed you back. i think you'll be very happy. all your concerns should be taken care of :-)
Username: Nd4spd18
Northwest PA
Post Number: 7567
If you like very bright tweeters CDT ain't the way to go.
Take a listen to some infinitys and the like. People who like the bright harsh sound usually love those. I can't stand it.
Username: Ninobrn99
Honolulu, HI USA
Post Number: 18
ive been debating between the cadence cvl-6k, rd elites, cdt es62i, and the re xxx. Not sure which I want. ive been searching here, ca.com and caf.com for reviews before I start a thread asking which one so I dont get flammed for it. So far, the Cadence handle a good bit of power and from what i've read, they're plenty loud and best of all, they're cheap. i've also been working with Mike@Exige on the CDTs. Im still undecided. Ive also began to install sound dampner on the doors to see if that helps.
Username: Exige
Cincinnati
Post Number: 347
Nino and I haven't been discussing silk tweeters. He was looking into aluminum and titanium DRT-26's. I wasn't about to steer him into a set of silks if chose the CDT's ;)
Username: Ninobrn99
Honolulu, HI USA
Post Number: 19
and I greatly appreciate it! Id hate to be disappointed again :-( Haha
