Coaxial and component
Username: Diehlerman
Post Number: 10
a bit confused on the matter but, what is the difference between coaxial speakers and component speakers? which is better?
Username: Ewok
Fairbanks, Alaska U.S.A.
Post Number: 68
coaxial is a 3way and component is 2way set, so woofer and tweeters are separated with Xover
Username: Nd4spd18
Northwest PA
Post Number: 6327
No, coaxial is a 2way speaker where the tweeter is built into the center of the speaker cone.
Component is a 2way or 3way separate midrange and tweeter with a crossover. Components sound MUCH better than coaxials.
Username: Exige
Post Number: 136
ewok you're killin me man...have a read: www.bcae1.com
Username: Nd4spd18
Northwest PA
Post Number: 6337
Yeah he really needs to stop giving advice when he doesn't even know this stuff
Username: Ewok
Post Number: 70
i had a coax before and its a 3way, thats why i said that, and i know the tweeter is attached into the middle of the speaker cone,
Username: Nd4spd18
Northwest PA
Post Number: 6363
That would be a triaxial. Basically a coaxial with an extra tweeter.
Username: Ewok
Post Number: 73
this is the 3way that i had before, TS-A12672Upload
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1538
That is a triaxial. Tri = 3. Co = 2.
Username: Exige
Post Number: 138
ewok.....did you edit your first post lol?
Username: Ewok
Post Number: 77
LOL, right on guys, you guys know everything
Username: Ninobrn99
Honolulu, HI USA
i thought copmonents use a xover and coaxis dont.
Username: Mike11202
RE MT 15 VFL 200.1 , Sewell, NJ US
Post Number: 1727
"i thought copmonents use a xover and coaxis dont."
Nope they both do, they usually have small crossovers built into the coaxials and some higher end coaxials have separate crossovers
my coaxial set is 3-way it sounds great- nobody calls them triaxle
