New member Username: Brigr88Post Number: 1 Registered: May-08 | Anyone with the correct knowledge know what i should do.. Ive hooked up systems before but i never paid attention to those details and im putting one in my car and want to do it right... Any help? |
Silver Member Username: BonhamdTC, MI USA Post Number: 635 Registered: Nov-07 | dual 2 ohm or dual 4 ohm? http://www.the12volt.com/caraudio/woofer_configurations.asp |
Gold Member Username: SomedonniedudeIllinois United States Post Number: 1573 Registered: May-07 | and what amp do you have? |
New member Username: Brigr88Post Number: 2 Registered: May-08 | Audiobahn 8001 mono channel amp and the sub is dual 2 ohm voice coils |
Gold Member Username: SomedonniedudeIllinois United States Post Number: 1583 Registered: May-07 | http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22 Wire it to 1 ohm/ option 1 I would take some precaution as 800w might be a little much for that sub. |
