Bronze Member Username: Banginfi1025COVENTRY, RI USA Post Number: 50 Registered: Sep-07 | IM LOOKING INTO 3 SETS OF SUBS I WANTED TO KNOW WHATS THE BETTER BUY. IM LOOKING FOR LOUD CRAZY CLEAN BASS. I PREVIOUSLY BOUGHT MONSTER CABLE WIRING 0 GUAGE WITH THE BIGGEST GUAGE MONSTER RCA'S A OPTIMA BATTERY AND A 220 AMP HIGH OUT PUT ALT. IM PUTTING MY SYSTEM IN A 1997 CHEVY BLAZER SO MY QUESTION IS FOR A BOX 38.5IN WIDE, 20 INCH HIGH AND 25 INCH DEEP WITH A 5 INCH PORT IN THE FRONT AND THEY WILL BE FACING MY HATCH WHEN INSATLLED THE SUBS TWO 15 INCH L7'S TWO 15 INCH RE SX'S TWO 15 INCH AUDIOQUE HD3 WILL BE POWERED WITH A HIFONICS 2600 WATTS RMS AT 1 OHM (ALREADY ORDERED no turning back) SO WHATS THE BEST BUY ? |
Bronze Member Username: Banginfi1025COVENTRY, RI USA Post Number: 51 Registered: Sep-07 | what type of port system should i do i was thinking a l shape should do it |
Gold Member Username: InsearchofbassPost Number: 9244 Registered: Jun-04 | assuming that you want more loud than clean im going to say audioque hdc 15's and yeah do a slot port with about anywhere from 2.00 to 2.50 cubic feet net per sub |
Silver Member Username: Hurricanebr1anWestern Burbs of Chicago, IL Usa Post Number: 534 Registered: Sep-07 | SO LET ME GET THIS STRAIGHT...YOU HAVE THE BOX ALREADY AND YOUR CHOICE IS TO EITHER GET SQUARE OR ROUND SUBS TO PUT IN IT.. HOW ARE YOU GOING TO WORK THAT? |
Gold Member Username: InsearchofbassPost Number: 9245 Registered: Jun-04 | the car we did has two audioque hdc 12's in aprox 3.45 cubic feet net tuned to 37-38 hz and hits very well on the low end still |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 7925 Registered: Feb-06 | the best buy is the competitor of circuit city sometimes u get crazy deals there.. but mostly on pcs and all that crap and not in the car audio department |
Gold Member Username: SomedonniedudeIllinois United States Post Number: 1549 Registered: May-07 | lol. Whats your budget? |
Gold Member Username: FrkkevinTeam DLS, Funky Town /... Post Number: 5099 Registered: Nov-05 | I loved my SXs for streetbeat.. too loud to listen to on full tilt but more SQ than the others you listed but yeah, budget would help.. could be some other subs out there for you |
Silver Member Username: Drant19DUB-C, TX Post Number: 961 Registered: Aug-07 | SX out of those 3 choices.. |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 2714 Registered: Jul-05 | I have an dual 4 SX 15" with a brand new recone that would be perfect for you. $220 shipped and has never been used before with the recone. http://www.caraudio.com/forum/showthread.php?t=316273 |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 5100 Registered: Nov-05 | Good price.. wholesale cost on that sub went up $20 from last I checked.. so pricing keeps going up on them |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 4530 Registered: Jan-06 | Ya, SX is the shiottt!!! Polo... |
Gold Member Username: MgbcsLincoln, Nebraska Post Number: 2501 Registered: Dec-06 | You've been asking this exact same question since the day you joined. Make a choice and be done with it. |
Bronze Member Username: Banginfi1025COVENTRY, RI USA Post Number: 52 Registered: Sep-07 | alright so from judging what you guys have said i should go with the sx's for clean and the l7's for just over the top loud that how im seeing it tell me if im wrong |
Gold Member Username: Nyyfan1315 Mag USA Post Number: 9643 Registered: Jul-06 | |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 4531 Registered: Jan-06 | Actually SXs are louder and can handle more power. I had one I ran a daily 2400 rms to it, on music then sold it and someone else played it for a while and then I think resold it lOl ? Polo.. |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 2716 Registered: Jul-05 | SX>>>>L7. |
Gold Member Username: MgbcsLincoln, Nebraska Post Number: 2502 Registered: Dec-06 | The L7s shouldn't even be on your list if you are comparing all these subs even up. The Audioque and RE will be both be as loud and sound better. Get whatever is cheaper between the AQ and RE and be done with it. |
