Bronze Member Username: Doconpoint1Park Forest, IL Post Number: 22 Registered: Jun-07 | Hey, i'm planning on purchasing a Kicker Sx1250.1, if i can get my hands on a decently priced one and use it to power 2 12inch kicker cvx's. But if i can't get my hands on one, what other amps do you guys suggest to power these 2 subs. also they are 4ohm DVCs |
Gold Member Username: SomedonniedudeIllinois United States Post Number: 1556 Registered: May-07 | Whats your budget? What car do you have and have any electrical upgrades? |
Bronze Member Username: Doconpoint1Park Forest, IL Post Number: 23 Registered: Jun-07 | My budget is 500, i don't want to spend more than that, i was looking for used kicker sx amps. I'm getting a different car within about a months time, so i don't have one right now. These suggestions are for just in case i don't come across a kicker sx deal that i like. |
Gold Member Username: Livin_loudCOD4 Addict ... Level 2 pre... Post Number: 2466 Registered: Jan-06 | those cvx's aren't too bad of subs, but they don't deserve to be on an SX amp. a KX would be much cheaper and work fine. |
Bronze Member Username: Doconpoint1Park Forest, IL Post Number: 24 Registered: Jun-07 | which KX would you sugest, i'm going for a 1 ohm load. If i don't come across an sx at the time i want to purchase, then kx will be the way i go i guess. |
Gold Member Username: Livin_loudCOD4 Addict ... Level 2 pre... Post Number: 2471 Registered: Jan-06 | 1200.1 |
Gold Member Username: 420alldaylongPost Number: 3606 Registered: Sep-06 | http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=3360 |
Silver Member Username: Dsmith07NC Http://com4.... Post Number: 803 Registered: Jun-06 | http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=kicker+sx1 250.1&category0= |
