Help picking out amp
Username: Surferdude9371
Im BTL Bumpin
Post Number: 922
budget is 150 for an aw1208t here are the specs
Sensitivity: 91 dB
RMS Power Range : 1500 Watts
Impedance: Dual 2 Ohm
Low Frequency response: 20 Hz
High Frequency Response: 500 Hz
Diameter: 12 Inch
Features
PHAT 2? Multi-layer Foam Surround
Stamped and Balanced Aluminum Cone
Dual 2 Ohm Voice Coils
1 Ohm or 4 Ohm Operation
6 mm Cast Basket
Multi-connect Lug Lock Terminals
frequency response 20-500 Hz
power handling 1500 watts RMS
sensitivity 91 dB
top-mount depth 6 3/4"
Username: Nyyfan13
15 Mag USA
Post Number: 9627
Not much you can do for $150 bud. I'd save up more and buy used.
Im BTL Bumpin
Post Number: 923
anything for 200 its for my buddy
Username: Drant19
DUB-C, TX
Post Number: 957
cheapest i can think of is a refurb kicker on ebay, or step that budget up for a AQ 1200d
Im BTL Bumpin
Post Number: 924
whick one the kx1250.1
Username: Nyyfan13
15 Mag USA
Post Number: 9630
No such thing as a KX1250.1. There is a KX1200.1 and an SX1250.1.
Doubt you'll find either on eBay for less than $200.
I'd up the budget just a little more and get an AQ1200d. Seems its hard to beat that amp for the price.
Im BTL Bumpin
Post Number: 925
thats what i meant kx1200.1 how much is the aq1200d
Username: Nyyfan13
15 Mag USA
Post Number: 9632
$250 I think. Check the audioque site.
Im BTL Bumpin
Post Number: 926
ok thanks bud
Username: Drant19
DUB-C, TX
Post Number: 960
ya or maybe check out hifonics for a budget amp.. however the AQ is MUCH better quality.
Im BTL Bumpin
Post Number: 927
which hifonics would work? im not lazy i just dont know how to match ohms lol
Username: Hittin1
LakeCharles LA., La
Post Number: 314
bxi1608... supossed to be 1600 watts rms at 1ohm... closer to 1400 watts rms. get the aq1200d... also around 1400 watts rms. better amp
