Need to know about 2004 Buick Century
Username: Sidmeister
Post Number: 85
I was wondering how I could run my power wire to my amplifier from my engine bay to my trunk...I cant seem to find a hole in the firewall to run it through...any ideas besides drilling a hole?
Username: 04redmach1
Columbus, GA USA
Post Number: 1952
Sometimes you got to drill. Or run under car and drill hole in trunk.
Kevin
Post Number: 86
k...well ive never drilled through something like that before...so what do i need to do it and is it very difficult?
Username: Nd4spd18
Northwest PA
Post Number: 7541
Umm, a drill and a bit. And a piece of rubber hose or grommet to go around the wire.
If it's 0 gauge wire a 3/4" bit is about right. Drill pilot hole first.
A pic is worth 1000 posts!!
Post Number: 16703
Silicon to seal it.
Trust me. I'm an Ex roofer. I know how water gets in. If it can it will.
Username: Nd4spd18
Northwest PA
Post Number: 7543
^^^^ That too, forgot to say that :-)
Username: •cam•
BC Canada
Post Number: 2514
And if you have a cutting... cutting... ah... cutting... f.ck. Well it's a liquid that makes the drilling of sheet-metal much easier. WD40 works decently but the real stuff is much better.
