Need pair of 10 or 12 subs for 140 shipped fast!!!!!
Username: Mike_16
Reedsburg, Wisconsin Us
Post Number: 911
anyone got any good deals or know wear to get some decent subs for this price
Username: Drant19
DUB-C, TX
Post Number: 945
ebay is your friend. you can probably find like some kicker cvrs, or some pioneers ts-w307s, or alpine type-s.
do you already have an amp?
Username: Dirtrider125
Post Number: 146
u can definately get some 12" cvrs for that on ebay
Username: Nd4spd18
Northwest PA
Post Number: 7503
Yea I think CVRs are the best good subs you're gonna get for that price. Also a pair of Audioque SD2 would be $200.......
Username: Mike_16
Post Number: 913
yes i only have 150 to work with. yea i found 2 12 cvr for 99 and 45 shipped :-) ... but and the alpine s for like 160 shipped. but ill check those pioneers . thanx
Post Number: 150
on onlinecarstereo.com u can get 2 alpine type s for 160 shipped i would do that
Username: Mike_16
Post Number: 915
would the s's be better than the kicker cvr? if so ill do it i just never heard them b4
Username: Mike_16
Post Number: 916
ok i cannot find 2 12inch alpine s dual 4 ohms on ebay or at onlinecarstereo.com either..i found dual 2 ohm and 10 inch but i want 12" . can you link me the page for that if u can?
Username: Rovin
Post Number: 13760
i would go with the cvr - they sound pretty good .....
Username: Mike_16
Post Number: 917
ok i found 2 12' s's for 160 and dual 4 ohm :-) .. ok now i just dont kno wwitch to get and i am ordering them in a few hours. so im not sure i had teh old kicker vr 10'' and they pounded but i have never heard the new s yet only a old one . so i need advive witch sub guys ???
Post Number: 152
the alpine sounds better and will be just as loud in a good ported box
Username: Drant19
DUB-C, TX
Post Number: 952
^^^fail
kicker cvrs would be louder than alpine type-s's. and as far as them sounding better, they will sound good as long as you put them in the correct enclosure. a good install can go a long way
Username: Hurricanebr1an
Western Burbs of Chicago, IL Usa
Post Number: 528
^x2
Type-E and Type-S are less than ideal woofers, which has always seemed strange considering how good the Type-R and Type-X woofers are...
Username: Mike_16
Post Number: 921
ok so ill be going kicker i guess!
