Kicker sx for 2 CVXs
Username: Doconpoint1
Park Forest, IL
Post Number: 22
Hey, i'm planning on purchasing a Kicker Sx1250.1, if i can get my hands on a decently priced one and use it to power 2 12inch kicker cvx's. But if i can't get my hands on one, what other amps do you guys suggest to power these 2 subs. also they are 4ohm DVCs
Username: Somedonniedude
Illinois United States
Post Number: 1556
Whats your budget?
What car do you have and have any electrical upgrades?
Park Forest, IL
Post Number: 23
My budget is 500, i don't want to spend more than that, i was looking for used kicker sx amps. I'm getting a different car within about a months time, so i don't have one right now. These suggestions are for just in case i don't come across a kicker sx deal that i like.
Username: Livin_loud
COD4 Addict ... Level 2 pre...
Post Number: 2466
those cvx's aren't too bad of subs, but they don't deserve to be on an SX amp. a KX would be much cheaper and work fine.
Park Forest, IL
Post Number: 24
which KX would you sugest, i'm going for a 1 ohm load. If i don't come across an sx at the time i want to purchase, then kx will be the way i go i guess.
Post Number: 2471
Username: 420alldaylong
Post Number: 3606
http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=3360
Username: Dsmith07
NC Http://com4....
Post Number: 803
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=kicker+sx1 250.1&category0=
