How to wire Quad 1.4 Ohm Voice Coil?
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2491
How the hell do I wire this? My amp is rated at 1 ohm so I would prefer to get it as close to possible to that number. Any help would be great. Thanks!
Username: Th3pwn3r
I compensate...
Post Number: 8066
You can wire it to 1.4 if you wire it in series parallel.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2492
Sounds like a plan to me. Thanks Rob
Username: Nd4spd18
Northwest PA
Post Number: 7500
Indeed. Then look at your amps 1 and 2 ohm ratings, and about half way between them is what kind of power you should get at that impedance.
