Newbie here, need some advice
Username: Gators02crew
Fl USA
I have a 2002 Ford F150 Supercrew and I'm wanting to build a Custom Sub enclosure from the back seat area to the front floorboard area(box will be made out of MDF & Fiberglass). I plan on running at least (3) 12" subs in the box The sub that I'm looking at is the MA AUDIO HK120XC 12". They are rated at 600 watts RMS and 1200 peak. They have a 240oz mag and have chrome baskets. The reason I'm interested in them is because I want to invert the subs so the baskets show. I want the system to not only sound good BUT look good....I show the truck. I have heard some MA's before and they sounded pretty good, but I want to know if there is something else that LOOKS GOOD AND SOUNDS GOOD TOO???? I'm not going to be competing in spl/sq stuff, but I would like it to sound good! I will be running a Kicker KX2500.1 @ 2ohm.
Thanks in advance!
here is the sub I'm looking at.....
Username: Talon01
Team Revolution , Pa Usa
Post Number: 1285
audiopulse done. next question
Fl USA
Which one?
Epic...Revo...Axis...LMS ultra?
Username: Talon01
Post Number: 1286
axis would work well for you
Username: Talon01
Post Number: 1287
oops saw you want 3. i would do 2 revo's instead
Fl USA
Thanks for the info
Username: Talon01
Post Number: 1291
np
Fl USA
Anyone else?
Fl USA
Post Number: 7
How about RD Audio?
