Visonik V4000XD amp?
Username: 71_chevelle
Post Number: 35
Is Visonik V4000XD Mono Block Amplifier a good amp? or am i just waisting my time with it?
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 6400
IIRC, its a pretty strong amp.
Same amp as the MA Audio HK4000.
I see them at shows from time to time. Cheap raw power...~3200w @ 2ohm.
As far as longevity, not sure.
Diamond Member
Post Number: 20928
not bad for a cheap amp i must say.
btw what is "IIRC"?
Username: Loudon
Post Number: 2449
if i remember correctly
a friend used one ... worked well for burps .. but daily it smooked .. blown fets and power supply lol .. on a solid 14v electrical ...
if ur daily driving with it .. i say no..
burps- i say yes
Post Number: 36
ok thank you thats what i was looking for.
so would you say HIFONICS BRUTUS BXi2008D would be a good amp then? it has a more recognizable name
Username: Bonhamd
TC, MI USA
Post Number: 661
what is your budget?
The AQ2200D for $389 is a pretty good deal
http://www.audioque.com/aq/AQamps2200D.htm
Post Number: 37
hmmm i was thinkin around $300
do you know of any amps that'll push 2000 watts rms around $300?
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2744
On a stock electrical you wont be seeing anywhere close to 2000rms for under 300 bucks. Unless you upgrade your alternator, big 3, and starter battery dont go above 1000-1200rms.
Post Number: 38
yes i am going to upgrade the alt and the big 3 and the starter batt. so then do you know of any amps that are around $300 that push 2000 watts rms?
St. Louis, MO / ASU
Post Number: 2745
Used AQ2200d or try and find 2 used ED NINe.1s and strap them.
Post Number: 39
ok i'll do that! thank you very much jake!
