ViewsatP--No Quality on 61.5 !
Username: Leo_here
Post Number: 66
Can somebody please advice me on this one?
Since last bin I have lost quality on my VSP. Has there been any changes in TPs?
Do I need a new satinfo.sat file?
Where should I get it from?
Username: Saqeeb9000
Post Number: 3280
is ur dish moved or something? check ur connection??
Username: Donnie1973
Post Number: 2979
if u unplugged it to program, make sure u connected it back up right
Username: Leo_here
Post Number: 67
My dish has not moved at all. I checked my connections..I am getting 584, 585 but nothing from 611 to 623.
My box is not even scanning any channel on 61.5...I tried my hooking up my CS and scanned...i got all the channels with good quality (No use still as CS is down at the moment but it givess a hint that my dish is ok )
Post Number: 2980
it could affect the quality. (ecm) maybe someone else with a cs and 61 will read and share what they are or are not getting
Username: Leo_here
Post Number: 68
One of my frind has the same receiver. He has not come across any such issues so far.
Where can I find the TP info to add channels manually?
Post Number: 2981
lyngsat.c0m
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2191
Leo if you use port 1 change it for 3 or 4
Old problem with port on viewsat
Username: Plymouth
Post Number: 2193
Leo if you use port 1 change it for 3 or 4 on LNB and switch
Username: Leo_here
Post Number: 69
I tried connecting it directly to only one dish...still no use !
Thanks everyone for prompt replies friends!
Username: Plymouth
Post Number: 2196
OUPSS
Post Number: 2984
oh, i read where u hooked up a CS to test, thought u had a CS. I dint read it carefully i guess. Yeah, try a new bin lie ply said. It should be working fine.
Username: Leo_here
Post Number: 70
Ply, if possible, please post the link for Viewsat Platinum's latest file. I believe it should be DBPSW080504. The path you gave is giving os for Pansat
X-87BL_080416_B75_263_api
Post Number: 2987
u can get it at ftaforall.net on the homepage
Username: Plymouth
Post Number: 2200
OUPSS
Username: Plymouth
Post Number: 2202
I'm sure this one is good
Username: Plymouth
Post Number: 2203
I' m sure this one is good
Username: Kirankumar
NO Bashing
Post Number: 2736
http://www.ftabins.net/showthread.php?t=38022
Username: Plymouth
Post Number: 2204
This one are out before ftabins
but fta bins is good site
Username: Leo_here
Post Number: 72
Thanks Ply....Lets hope this works !
Username: Plymouth
Post Number: 2205
African what is your username on ftabins
Username: Plymouth
Post Number: 2206
Leo your box work now?
Username: Leo_here
Post Number: 75
Still not working man ! This sucks !
Username: Plymouth
Post Number: 2218
You can do a fatory default
do a hard reboot
and reload bin
dont load factory bin
good luck
Post Number: 2993
make sure ur antenna settings havent changed. look over everything,99% of the time there is nothing wrong with the box.
Username: Leo_here
Post Number: 78
My antenna settings are
Satellite: Echostar3 61.5
LNB Power: On
LNB Type: Standard
LNB Freq: 11250
22KHz: Off
TP Freq: 12224
DiseqC 1.0: Port 2
Motor: Off
Legacy SW: None
I tried changing TP Freq
I tried changing the ports
I tried adding the channels manually.
But it's still not scanning channels from 611 - 622
Username: Leo_here
Post Number: 82
Latest Bin installed as well !
Username: Plymouth
Post Number: 2269
Leo try it:
Try it exactly as write
All viewsat box
Go to Code menu
Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider one by one with F3 on remote
"NEW" do same thing with all provider on Bev provider
09 07 00
09 06 00
09 05 00
09 01 00
08 01 00
no need to delete keys
and load last bin for your box
turn autoroll on
Keep on
Bin and autoroll regenerete keys
Thats erase bad data in the box
For box who autoroll and lost channels
I hope that work
Good luck
Thanks
Reply if it work
Please
Username: Leo_here
Post Number: 83
I tried it Plymouth..
Still no luck...its scanning only 14 channels like before
Username: Plymouth
Post Number: 2306
Leo where you live Province or state?
Username: Leo_here
Post Number: 84
Ply I live in Brampton, ON
Username: Luser
Post Number: 298
many channels have recently been removed from 61.5. Ck lyngsat under packages then click dishnetwork for all current channels
Username: Nydas
Post Number: 10625
My friend just did a blind scan on 61.5W . He lives just west of Brampton.
He got 9 transponders instead of 13 and channel count is down from over 140 to about 104.
All the Indian and Arabic channels are OK. The missing TPs, I am told, might be Mpeg-4
Username: Plymouth
Post Number: 2335
Nalin is right some tp are changed,
just to do a blind scan, that recover new Tp
Username: Leo_here
Post Number: 85
I added the specified TPs as per lyngsat.. NO USE !
I blind scanned all TPs individually..No USE!!!
My CS, PSconverted to PUFF and SV are scanning all 13 TPs with over 140 channels!!!
Thats it for my VS I guess
