NO SIGNAL - Strange! tryed all usual methods
Username: Tt88
Post Number: 22
Using puff 265 pansat 2500 clone
no signal. unplugged cable then plugged back.
tried all other methods.
any ideas?
Username: Nydas
Post Number: 10653
Do you mean, it was working with the latest PUFF BIN, and just stopped?
If so, instead of wasting time, if there is light just go through the 4 stage procedure of
1. b60 boot using 2700 to 2500 loader.
2. 294T BIN using BL updater 1.4
3. PUFF_253 special boot/BIN 640K.
4. Latest BIN from another author - there are 6-7 versions out.
You can also save current settings using channel master and restore after loading.
Username: Kayoss
Post Number: 51
Then start all over again.. because it still wont be working!
Username: Shadow45
Mty, Nuevo Leon Mexico
Post Number: 271
I actually started having trouble with the signal too since i installed the 265 bin..i thought my antenna might have been moved by wind and all, but it wasnt..now, i turned the tv on and no signal whatsoever...did the back switch reboot and NADA!.
Now that i see you post i know it wasnt anything else but some type of bug in the bin, hope this guys get it fixed , the previous ones had been working flawlessly.
