Nalin pls post B 75 file for 2500 clone => 2700
Username: Aryan
Mississauga, Ontario Canada
Post Number: 59
where is your magic box all in one. i do not trust any thing else.
thanx
Username: Nydas
Post Number: 10684
There are no b75_266 files available yet.
There are three PUFF_266 files.
[link removed]
Username: Aryan
Post Number: 60
should i switch to puff or stick with B 75 pls advise.
if Puff is better then also paste link for "how to convert in to puff"
thanx
Username: Nydas
Post Number: 10692
aryyan: Every thing is available at:
http://public.box.net/2500_full_kit
The folder names indicate what you want to end up with, not what you are starting with.
Conversion to PUFF is easy and converting back to b60 and b75 is also easy.
As of now there are no b75 files out.
Username: Aryan
Post Number: 61
Thanx nalin,
i am puffed now, but i have a question now what my receiver will be called now
it was a 2500 clone
then converted to 2700
and now puffed
pls clearify, and thank you VERY MUCH
Username: Nydas
Post Number: 10697
PUFF converted.
When you load you new BIN, take a deep breath and say
P.......U.......F......F
Username: Metallica
Post Number: 690
(Mr.PUFF)..sound good
Username: Dimwitt
Post Number: 686
www.ilikepuffies.com/
Username: Jkmago
Post Number: 200
Did you exactly follow what is written in Nalin kit? Can you confirm as some one wants know about the same.
Thanks
Username: Letmeon
Post Number: 225
Since the PUFF convert kit includes a
2700 -2500 loader file.
Therefore the PUFF version comes under the 2500 Pansat list.
PUFF is better. U don't have to reload all sat scans after each update as in B75.
Username: Polo69
Post Number: 36
B-75 bin 266 is just out:
wwww.ftatalk*com/showthread.php?t=174167
enjoy tv
Username: Jwl1
Post Number: 300
Unless the pages are not refreshing properly, the B-75 is not yet out at at ftatalk. Only the Puff which came out yesterday evening.
Username: Jkmago
Post Number: 201
here is another link for B-75 non Puff
Dans B75_266
http://www.dssrookie.com/forums/b-font-color-990033-flu-pantec-2500-to-2700-file s-font-b/dans_266_b75-204663.html
