i have a converted pansat 2700a with puff. I m getting most channels but i am not getting the channels... wlne wjar wlwc wsbe I have a 61.5 these channels worked b4 but not any more any idea wat i could do
All these four channels, i.e. wlne....wjar....wlwc....wsbe are on the above mention TP.
Do a specific TP scan of that TP and you should get them. If you don't see that TP add it on the TP list. There is no point doing a Blind scan (which is another way of getting them) if those are the only ones missing.
nalin i added the TP like you said but i still am not getting any quality. I added the Tp like this ... Tp 12442 Mpbs 20.000 and H
The settings that are automaticly set are this..
Lnb Type: Standard LNB located Freq: 10750 22khz: OFF Diseqc: OFF Legacy SW: None Skew: 45 Tp: 37(12442) H 20.000 Setting: Disable The level is 75% with 0% quality I only have one satellite pointed to exactly 61.5
I live in Montreal and i need the correct timing for the user settings so plz tell me if that is the problem or not
Nalyn, I see that now we have to convert on Puff. I tried to do sow. I have a flu since 2006 and I had now problem for any changement until now. Now when I try to convert to Puff I follow the steeps using Boot60 with 2700 to 2500 conversion software by Chancysand but I have an error to load the Boot60. I tried with receiver on or just turn on and start writing, but I have all the time same thing the Boot b75 is all the time there no possibility to convert. Do you have any idea what I can do for that? Thanks.
Vincent: With receiver saying ON, and correct cable, the 2700 to 2700 special loader by chancy set to Boot (not bin) should load the b60 boot file and end up with a night rider light going across. Are you sure of your cable - you need a straight RS232.
oh..... oh well thank u very much for helping a noobie like me i really appreciate.. Thank u once again Nalin and the others that help me I really appreciate it
Nalin, I allready did that, I never had problem for any conversion(flu to pasat 2500 and pansat 2500 to pansat 2700) since september 2005 and I use all the time the RS232 cable. I use b75 but I see that it starts to take more time to get a new file. I tried with receiver on, or just started no change. I tried when PUFF just came and still now with new packige still same thing. I tried boot. And I see that nobody had problem with the conversion, but it doesent work for me. Any other idea?
