Silver Member Username: Donyahelwa
Post Number: 197 Registered: Feb-06
Posted on I'm having problems with editing TP's for some of Arabic channels (OR all of Arabic channels). I'm wondering what sat they set on right now and what are the TP's. I have tried to locate them and I did edit some of the TP's and did a Blind search but no chance. I couldn't get any. I used to have them, but they have moved months ago and I didn't bother to get them back. I used and added Arabic TV TP's to sat then I did a blind search for these sats: Echo3 61.5 and Anik-F3 118.7 If any one out there can share his/her Arabic/international settings, I thank you in advance. Or any one else with a helping opinion, I would appreciate it too. |
Platinum Member Username: Nydas
Post Number: 10621 Registered: Jun-06
Posted on Echo3 61.5W Ch..Name...TP.....SR 672 DANDA 12660(V) 20,000 AR 649 DUBAI.. 12329(H) 20,000 AR 646 ESC1... 12324(H) 20,000 ?? 777 HKYAT. 12660(V) 20,000 TU 662 IQRAA.. 12329(H) 20,000 AR 670 MBC..... 12630(V) 20,000 AR 671 MLODY 12602(V) 20,000 AR 647 NILE..... 12324(H) 20,000 AR 673 ZOOM.. 12650(V) 20,000 AR Also look at this - English but heavily Middle East orientated. ECHO 8.10 (110W) 9410 LINK 12355 (H) 20,000 EN |
New member Username: Kelly8888
Post Number: 7 Registered: Dec-07
Posted on Where are the Chinese channels go? Thanks! |
Post Number: 198 Registered: Feb-06
Posted on Thanks Nalin. |
Post Number: 10642 Registered: Jun-06
Posted on Chinese channels on which sat? |
Silver Member Username: Mucho
Post Number: 252 Registered: Dec-07
Posted on Chinese TV Channels.
http://ekb.dbstalk.com/118list.htm
