Fi Q vs. Hdc3
Username: Jt212
Post Number: 34
looking into a 12" that will do 1000w rms and landed on these two subs. I have a trailblazer and im going to throw 1200w rms into each. im wondering which will sound clearer and louder, i know everybody might hate these questions but im stuck
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2137
Those are two completely different subs. The Q's are SQ subs, and the hdc3's are SPL. The audioques will get louder and still have ok SQ. The Q's will have much better SQ and will hit the lows better than audioques but wont get as loud.
If you want to be straight up loud, get the audioques.
I own a pair of the old sd2.5's and they pound.
Username: Somedonniedude
Illinois United States
Post Number: 1520
Whats your budget? Are you looking for something loud and clean or mainly loud but retain some quality?
Username: Jt212
Post Number: 35
i dont want to spend any more then the 280 because thats what the Q would cost, i want something that will be loud and clean because i want a sealed box but i will go ported if needed
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5818
definitely go q for sealed. hell i would go q even if you went ported.
Username: 420alldaylong
Post Number: 3576
Fi BL would sound great on 1200RMS of course ported.
Username: Denim
SoundSolutionsAudio.com, MD USA
Post Number: 716
I agree with Reece. And Joey brings up a good point, I think the BL is more comparable to the other driver.
