Kenwood KDC-V6017 NO SOUND
Username: Jer0jon
I bought a Kenwood KDC-V6017 Deck it powers up and all the functions work but I have no sound does anyone know what could be wrong
Username: Kpa2727
Old Bridge, NJ USA !
Post Number: 1203
check connections to your speakers and fader settings otherwise internal amp could be blown , did you buy new?
Username: Jer0jon
I bought it used, I double and triple checked conections, so it must be the amp, is the stereo worth fixing or do you think it is junk?
Username: Kpa2727
Post Number: 1206
only way you can prob fix it would be sending it back to kenwood. unless u paid a hefty price, it's probably far from worth it. if u decide to junk it do 2 things before you do. 1 check the back of the unit for fueses see if any are blown, 2 opwn the housing of th unit and take a look inside see if you find any internal fuses and replace them to. one last thing i can thing of, if theres a harness, check the pins in the harness and see if they are intact and not pulled out. oh and have u everchecked to make sure a speaker wasn't groundng out on the body of the car?
Username: Jer0jon
thanks for all the info I will give it a try
