Bronze Member Username: YoungkPost Number: 12 Registered: Apr-08 | 2 15' Kicker 07 Comp subwoofers. Going to run them at 4ohms. Need a good amp. Budget is around $200-300. Also could I use a mono amp if I wired them together or something? |
Silver Member Username: Dirtrider125Post Number: 128 Registered: Apr-07 | i have a kicker kx450.2 for sale it would be perfect for them does 500 rms @ 4 ohms bridged. will sell for $200 shipped wit a tracking number |
Silver Member Username: Dirtrider125Post Number: 129 Registered: Apr-07 | ![]() |
Gold Member Username: 04redmach1Lagrange, GA USA Post Number: 1884 Registered: Mar-06 | Aren't the comps single 4 ohm? Kevin |
Bronze Member Username: YoungkPost Number: 13 Registered: Apr-08 | Each sub is 4ohms. Kicker 750zx will only give out 375rms @ 4ohms. So I will prolly need 2 amps right? |
Gold Member Username: SomedonniedudeIllinois United States Post Number: 1508 Registered: May-07 | Nope. You will need an amp that does 500w rms @ 2 ohms. zx500.1 would be a perfect match for those. There is guy on, Paul Larrea, who has a brand new one for sale. Send him a PM in the link below... https://www.ecoustics.com/cgi-bin/bbs/board-profile.pl?action=view_profile&prof ile=wingmanalive-users |
Gold Member Username: 04redmach1Lagrange, GA USA Post Number: 1887 Registered: Mar-06 | I have an Ample Audio amp that is 500 rms at 2 ohms mono. Comes wit 1 year warranty for $235 shipped. Kevin lowhz01@yahoo.com |
Silver Member Username: Dirtrider125Post Number: 130 Registered: Apr-07 | you can hook them up to this amp hook 1 up to each channel you will get 250 rms x 2 @ 4 ohms. so each sub will get 250 rms. |
Gold Member Username: 420alldaylongPost Number: 3556 Registered: Sep-06 | A guy a know had 4 15" kicker Comps on a Rockford T3002 and it was bangin good. He had the4subs wired to a 1ohm load so the T3002 would bang the hell out of those 2 you have just wire them to 2ohm anther you go. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19509 The spec are wrong^^^^^go to RF website and see real ratings. www.rockfordfosgate.com WAY WAY UNDERATED |
Gold Member Username: SomedonniedudeIllinois United States Post Number: 1519 Registered: May-07 | "you can hook them up to this amp hook 1 up to each channel you will get 250 rms x 2 @ 4 ohms. so each sub will get 250 rms." How do you figure? |
