Username: Jmonte Havana,
CUBA
Us
Post Number: 9 Registered: Feb-07
Wednesday, May 14, 2008 - 15:07 GMT need help, my vs ultra froze as i was down loading latest file with flash drive. dont want to power down what can can i do. any advice is appreciated.
Username: Kirankumar NO Bashing
Post Number: 2787 Registered: Oct-07
Wednesday, May 14, 2008 - 15:43 GMT remove flash drive
Username: Nydas Post Number: 10696 Registered: Jun-06
Wednesday, May 14, 2008 - 16:29 GMT You may have to load factory BIN using cable and Loader, and then reload the latest BIN
CUBA
Us
Post Number: 10 Registered: Feb-07
Thursday, May 15, 2008 - 00:07 GMT thanks ,i heard froze fix is also good
Username: Way2smart Www.Desifta.com
Post Number: 1616 Registered: Oct-06
Thursday, May 15, 2008 - 00:12 GMT yes it freezes use the cable.....i loaded mine with usb but froze then used cable working fine
Username: Plymouth Quebec city,
Quebec
Post Number: 2400 Registered: Jan-08
Thursday, May 15, 2008 - 01:21 GMT j monte Load this mainpg.pgm with cable http://www.box.net/shared/ytdcaz604o After it load last bin Good luck
CUBA
Us
Post Number: 11 Registered: Feb-07
Thursday, May 15, 2008 - 03:37 GMT THANKS PLYMOUTH WILL GIVE IT A TRY
Username: Kingofdakingz Post Number: 258 Registered: Jun-06
Thursday, May 15, 2008 - 12:16 GMT thats what i did yeaterday my receiver frozed and what i did was i loaded the latest factory bin and then i loaded the latest bin USING NULL CABLE (NOT USB IT WONT WORK)
Username: Rtf Post Number: 47 Registered: Aug-07
Thursday, May 15, 2008 - 14:29 GMT try a hard reboot before you upgrade using USB.
Username: Hawaiian_time Kanaka freak...
Post Number: 1903 Registered: Apr-06
Thursday, May 15, 2008 - 17:56 GMT Seems this latest bin for the ultra problem affects some of the receivers. It won't load no matter what you try to do. An older bin will load normally after you flash the ultra with a factory bin. Hopefully a new bin will come out that addresses this problem.
Quebec
Post Number: 2406 Registered: Jan-08
Thursday, May 15, 2008 - 20:27 GMT Warning, if you use factory bin from Viewsat. Thats why you freeze, this bin is corrupt
