Hey so i just put up a new dish today and i am having a heck of a time catching echostar 61.5.
I am able to catch Nimi2, 82 just fine with good signal. basically according to Sat Calculators once i am locked into Nimiq 2 i have to just drop my angle down 3 degrees which i did and move the sat to the left which i also did.
I am catching signal but the sat is not identifying itself, and the signal is bouncing up and down between 0 and 75
this is my antenna setup
legay sw none motor off diseqc none tp freq 12297 22khz off lnb freq - 11250 lnb: standards
im in the toronto area can the hesight at which i am mounting the dish matter - i am installing it one afence post - from there i CAN catch nmiq 2 and 1,3 fine but you think maybe i should go higher for Echostar 3 maybe on a wall?
- 61.5 (echo-3) is about 10 degrees counter-clockwise from 82 and slightly up not down if yo are on east cost (Toronto area)
- DN have been slowly adding more HD on 61.5 so yo might want to try TP 12326
- Selecting Universal LNB might be better than standard
- Any time yo get signal up and down it it is a frequency issue caused by mismatch LNB type to selected TP on that freq mainly I think yo are on wrong satellite
Good luck Come back and tell me how that worked for yo But yo should be up and runing in few minutes if yo do what I tell yo
i ended up taking everything down - tomorrow i will start again and actually mount on the wall right now i was trying ona wooden fence post.
i think i may have a line of site issues as well - but ill see.
on thing i noticed is when i change the TP frequency and hit exit it does not ask me to save.. like it does when i make other changes... then if i come back into anetnna set up i notice tp freq is back to its default settings - any idea what i could be doing wrong?
hey african so i caught it!! i got echo 3 but again same problem i cant get antenna settings to keep 12326 ..... as long as Tp is on 12326 i am getting good signal but as soon as i hit exit and go out and come back in it is back to default - i cant make is stay of 12326 any suggestions
